Old 07-12-2006, 12:01 AM   #1 (permalink)
Lightbulb Best AMD X2 Solution For Under 6000
Hi!
Wish to know the best AMD x2 solution for under 6000. Current config:
AMD Athlon XP 1800+
Kingston DDR 266 256MBx2
MSI KT4AV
MSI GeForce FX 5200
So now ... tell me the best possible solution ... where I may get onboard audio (not necessary) and graphics.
Will I be able to use my present AGP 8x graphics card on the new board?
Thank you.
Gravitation can not be held responsible for people falling in love- Einstein.
jainshubhanyu is offline
Old 07-12-2006, 01:06 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Best AMD X2 Solution For Under 6000
hmm.. 6k is very little with ur corrent requirement... u can hardly fit AMD Athlon 64 3200+ with a VIA chipset based board... then again 939 based boards dont have AGP slot...
u r asking for AM2 based processor ... well AMD X2 3600 may come under that 6k budget... but ur mother baord wont support...
u have 266Mhz RAM... it will run with AM2 or any other Available AMD 64 processor but 400 Mhz should be used for best performance...
so... either increase the budget now or Wait and then when u can increase the budget then go for the update...
ur present system isnt that bad ?? .... !!
P.S. get a price idea http://www.deltapage.com/
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-12-2006, 09:06 AM   #3 (permalink)
assasin's Avatar
[quote=saurav_cheeta]u have 266Mhz RAM... it will run with AM2 or any other Available AMD 64 processor but 400 Mhz should be used for best performance...
AM2 uses DDR2 ram and socket 939 runs on DDR.so if he buys AM2 he wont be able to use his present RAM,though it'll work perfectly with a socket 939 mobo.
assasin is offline
Old 07-12-2006, 01:24 PM   #4 (permalink)
Talking Re: Best AMD X2 Solution For Under 6000
I want to sell my current processor motherboard RAM and graphic card; and go for an AMD X2 solution. OK, budget increased to 8k, but this should include everything - ram, proc, mobo, graphics.
Sound I will use from either any onboard if present, or my Creative Sound Blaster Live 5.1.
Old 07-12-2006, 01:27 PM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
whether u buy 939 pin or am2 socket, your ram will cost your around 3.5k for 512 mb of ddr or ddr2.
then u are left with around 4.5k for your mobo n proccy.
u can access the situation yourself
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 07-12-2006, 01:34 PM   #6 (permalink)
Rebooting
u cant fit in a good config in that budget... suppose AMD Athlon x64 3000+ at 3k an nForce based Mobo, lowest can be at 4k range so u eat up 7k here..
DDR ram's are now going up day by day... so 400Mhz 512 Mb around 3.5k...
stick with ur present system...
u cant fit in a good config at 8k... wait till u can increase it...
rebooting
ChotoCheeta.com
Old 07-12-2006, 01:36 PM   #7 (permalink)
The main probs now is the cost of RAM. They are just rising by day n showing no signs of coming down
Sony Vaio CW26FG
Old 07-12-2006, 01:54 PM   #8 (permalink)
Lightbulb Re: Best AMD X2 Solution For Under 6000
I get 512MB of DDR2 for 2500 here in Nehru Place .... hey let's leave the ram, let the budget exclude ram. Now what do I get?
__________
Alright ... now is there a difference between an AM2 and an X2? If yes, which is cheaper? I understand that the sockets are same for both, so we may go with a lower processor right now and upgrade the processor later.
Last edited by jainshubhanyu; 07-12-2006 at 01:54 PM. Reason: Automerged Doublepost
Old 07-12-2006, 02:16 PM   #9 (permalink)
samrulez's Avatar
Originally Posted by saurav_cheeta
u
eehh! Its around 2.8k...not 3.5k....
Sam :D Rulez :lol:
samrulez is offline
Old 07-12-2006, 02:39 PM   #10 (permalink)
AM2 is the socket type , whereas the X2 is the dual core from AMD
Sony Vaio CW26FG
Old 07-12-2006, 05:00 PM   #11 (permalink)
assasin's Avatar
Go for Socket 939 it will be in ur budget,AM2 will cost u bout 10k( mobo + proccy ).
Athlon 64 3000+( Socket 939 ) + Asus mobo = 6.1k
assasin is offline
Old 07-12-2006, 08:45 PM   #12 (permalink)
Well then .... time to go to the dealer to check prices ...
assassin ... you have crossflashed your drive. Why so? Any performance increase? How'd you got it done?
I got an 820A... can I get my hands dirty tooo?
Old 07-12-2006, 09:34 PM   #13 (permalink)
assasin's Avatar
Just search 4 it on d net,though i dont think dat u can crossflash it to a BenQ.
assasin is offline
Old 07-12-2006, 09:38 PM   #14 (permalink)
wat is crossflashing? can it be done with HP?
Sony Vaio CW26FG
Old 08-12-2006, 06:23 PM   #15 (permalink)
That's the thing ... could not get credible (read which could go in my head) information regarding crossflashing and its advantages...
I am not exactly a newbie....I have flashed my bios for mainboard and dvd rom a fwe times ... once even flashed the bios of my graphic card ... but can't get this crossflash thing.
Old 09-12-2006, 12:54 AM   #16 (permalink)
assasin's Avatar
Most companies use rebadged products of other companies and sell it with their label.e.g SONY DRU 720A & DRU 800A r rebadged LiteOn 1673 & 1693S.Also LiteOn 1673 & 1693S r d same.
Crossflashing is a technique wherein u can convert ur drive to the original product i.e u can crossflash a Sony DRU 720A to a LiteOn 1693S.Crossflashing does give some performance benefits but not always.Crossflashing is dangerous,it can kill ur drive.
@codename romeo It depends on wat model of HP optical drive u have.Cuz not all drives r rebadged products and its not dat u can crossflash each and every rebadged product.
assasin is offline
Old 09-12-2006, 01:56 AM   #17 (permalink)
Mine is HP DVD 735
Sony Vaio CW26FG
Old 09-12-2006, 03:01 AM   #18 (permalink)
Thumbs up Re: Best AMD X2 Solution For Under 6000
[quote=assasin]
RIGHT SAID !!!!!
Genius_mod is offline
