Old 06-12-2006, 11:32 PM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default SATA to IDE Convertor ?????
One of my friend wana upgrade his config, new mobo with old HDD(IDE). Is there any way so that he can connect his IDE HDD to SATA port ??????
CadCrazy is offline
Old 06-12-2006, 11:40 PM   #2 (permalink)
The High 5 Flyer
sam9s's Avatar
Default Re: SATA to IDE Convertor ?????
There is no need for converter, the mobo must be having atleast one IDE cable port. Otherwise you wont be able to connect even a ROM drive.
sam9s is offline
Old 07-12-2006, 12:45 AM   #3 (permalink)
gg_3000's Avatar
ya, u r rite! There's no need of a convertor! Any mobo shud definitely support IDE.. Also, there's no such convertor thats available 2day.. I dont think that we would see such a convertor, given the difference in technology between them!
Google - What's that?
gg_3000 is offline
Old 07-12-2006, 10:02 PM   #4 (permalink)
in search of myself
CadCrazy's Avatar
But modern motherboards have only one IDE connector. So either CD Rom or HDD can be connected at a time. So is there any other solution
CadCrazy is offline
Old 07-12-2006, 10:27 PM   #5 (permalink)
yes.....there are IDE==>SATA converter out there, but no need to buy one.....you can use your cd-rom ide port to connect your hdd, both will work simultaneously, so no need to worry.
jack// ani is offline
Old 07-12-2006, 10:59 PM   #6 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Ya! Both will work simultaneously but there can be a fall in performence due to simultaneous work.
So what I want to suggest is, just try what other members have told u & if u face any prob or lowering performenece, buy a converter.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 08-12-2006, 07:27 AM   #7 (permalink)
in search of myself
CadCrazy's Avatar
How much the convertor will cost. Is it a cable only or an add on card
CadCrazy is offline
Old 08-12-2006, 07:49 AM   #8 (permalink)
nishant_nms's Avatar
Ya there are only one IDE port on Intel boards but u can connect two drives on a IDE port
nishant_nms is offline
Old 09-12-2006, 12:15 AM   #9 (permalink)
The High 5 Flyer
sam9s's Avatar
There is only one IDE connector but the cable has two junctions. so you can make your HDD, Primary Master and your ROM drive as Primary Slave. You can connect a HDD and a ROM, two HDDs or two ROMs with a single IDE cable, which ever combination suits you.
sam9s is offline
Old 09-12-2006, 07:27 AM   #10 (permalink)
Tushar.bar's Avatar
Thumbs up Re: SATA to IDE Convertor ?????
After that if u need another ide port(to attach another cd drive or Hdd) simply buy a pci 2 ide convertor.
Tushar.bar is offline
Old 09-12-2006, 10:38 AM   #11 (permalink)
Pci i/o card use for IDE drive
and
pic to sata card also available
nirali is offline
Old 09-12-2006, 12:09 PM   #12 (permalink)
Ray
Precision Processor
Ray's Avatar
It's better to buy a new SATA hdd rather than wasting money on a sata card.If the IDE hdd has important then install both the IDE and SATA drive together and then use softawares like Acronis Image Maker to make image of the IDE drive and copy it into the SATA hdd
Successful and unsuccessful people do not vary greatly in their abilities. They vary in their desires to reach their potential.
Ray is offline
Old 10-12-2006, 12:34 AM   #13 (permalink)
For a friend of mine, who had two CD drives and and an 80 GB, I had to buy a PCI card which supported two IDE channels. But this bypassed the onboard IDE controller..
the card was of 900-1000 bucks w/ warranty
ashnik is offline
