06-12-2006, 08:23 PM
Black turned green.
hey everyone,
the black color on my monitor has turned green and it looks too bad. Can anyone help me???????? im using samsung samtron CRT.
06-12-2006, 08:50 PM
Re: Black turned green.
What black colour?
06-12-2006, 08:55 PM
Hanging, since 2004..
^^Black color of the plastic case/cover ofthe monitor .
Try for a replacement cover at the samsung service centre, they must have it.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
06-12-2006, 10:11 PM
no, the black color on the screen.
07-12-2006, 12:44 AM
No pain....No gain
Try to degauss the monitor urself or better call in the technician. Post a screenshot of ur problem.
07-12-2006, 12:46 AM
That was a good One!1
Google - What's that?
07-12-2006, 12:56 AM
Degauss it,it's most probably due to stray magnetic interference.
07-12-2006, 01:26 AM
Will a screenshot show you green? lol
07-12-2006, 12:06 PM
lol ,
btw many time the colors are shown improperly due to faulty monitor cable , happened with my friend ,his monitor used to show pinkish color ,changed the cable and all ok.this may be the case.
Windows 8 ? :lol:
07-12-2006, 12:20 PM
Maybe one of the pins is broken in the monitor cable
07-12-2006, 12:26 PM
No pain....No gain
hehe....my mistake. lol
08-12-2006, 01:56 AM
look bro... its only that your contrast and brightness levels are improperly set decrease your brightness to see if it work and if dont then change you color temperature... after that if this also does not work then just try to fold your monitor cable from different angles and see if it work... can be possible that cables gone a bit ripped up....
08-12-2006, 02:14 AM
hey btw ... just make sure someone didn't screw up with the gamma, brightness, contrast settings of your display driver ! You can usually find that through Control panel and then display properties ...
