Re: Best performance from RAM
For a Pentium i'd always suggest Dual Channel , even for mismatched modules .. the mobo should be smart enough to detect the ideal latency combination for the modules .. from what i can see u may try the 2.5,4,4,8 for all the modules ..
Also , the strange thing is that the FSB:RAM ratio is 5:4 in default ... it should be 1:1 .. see if u can manually select the RAM freq. from the bios .. if so then set it to ddr400 (i think even Intel Originals will let u do this) ...
