05-12-2006, 09:40 PM
pci e grafix cards...which one 2 choose
hi friends
i hav pc config.........amd 3000+,MSIrs480,512 ram....
i need a grafix card...around 4k......
which one 2 take...
7300 adn 7600 series are there....but donno price and which one is better....there is also GS n GT two versions....which one is better
05-12-2006, 09:44 PM
Romeo + Lucifer = ME
Re: pci e grafix cards...which one 2 choose
for 4 k go in for Palit x 1600 ......... According to digit it rocks
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
05-12-2006, 11:02 PM
The High 5 Flyer
Geforce 6600GT.....Best bang for bucks, 7300 would cross budget, by a small margin though, I am not sure but 7600 is definately expensive for you. 7600GS around 7000-8000 and 7600GT around 10,000-11000.
05-12-2006, 11:08 PM
what about geforce 8800.when it is gonna be out whats the COST.
05-12-2006, 11:25 PM
The High 5 Flyer
Its out and its 25000+ wanna go for it. Well on the positive note pricses for 7950 would drop to an affordable extent.
05-12-2006, 11:34 PM
but 7 does not support dx 10 so investing in it would be foolish
__________
it is between 35k-40k worth every paisa.
Reason: Automerged Doublepost
06-12-2006, 12:01 AM
The High 5 Flyer
How many games do you have currently fully utilizing DX10....None, all under production, apart from crysis2, which itself is not out yet. By the time we have loads of games for DX10. 8800 would be under 20K belt. Which is easily a year from now. So spending in a 7950GTX(which in itself is an awsome card) now would not be that foolish after all.
06-12-2006, 12:02 AM
7300GT costs Rs.3300 in mumbai. 7600 is way beyond your budget. 7600 is much better than 7300. GT is much better than GS. Both in 7300 & 7600 u will get 3 kinds i.e. LE, GS & GT but GT is the best of the three than comes GS & LE respectively.
06-12-2006, 12:11 AM
i m talking about long time investment dude.i will not buy 7950gtx for only 1 year and then again purchase any geforce 8 series card.
06-12-2006, 12:51 AM
The High 5 Flyer
In todays world of computers is there a long time investment???......if you hardware is worth for 1-2 years you are good.
06-12-2006, 01:52 AM
if i buy 7950 now i will have to spend two times (for 8 also)over graphics in an year.i m better off with my 6600 for atleast seven eight months.
06-12-2006, 07:22 PM
hey wats price of 7600gs...and 7600gt.....and wats difference betn them....gt is better tht i know...adn which is better 7300gt or 700gs....cause if it is affordable then i will go for it
__________
and i want 2 ask another q is tht....for new generation grafix cards...do they need more power supply.....cause one of my frined has 6600..he told me tht...he ahd 2 buy a new power supply...i dont rmember perftly but i think normal 240 v wont work...we need 330 v power supply....is it true ?....wats its cost
06-12-2006, 10:21 PM
Considering the poor support for dx10 right now , and not having any dx10 game before Q3 2007 , i can say a little thing : dx9c will still be mainstream till the end of 2007 , no matter how much MS may try to put dx10 ahead ... u just can't have a major platform shift overnight .. the transition period will be slow and very slow ...
Getting a 7 series wouldn't hurt right now ... it'll easily do good till the end of 2007 (if its a high end 7 series i.e. 7900GS and above) .. and then a little shift to dx10 midrange cards (G84 are supposed to be out Q2 2007) .. maybe 8600GT's will be the target ..
07-12-2006, 04:18 PM
The High 5 Flyer
You said it pal
10-12-2006, 07:53 AM
I have already answered thr first part of your question in Post No#8 ...pls read the replies before asking the same question.Yes you do need a good powersupply with todays graphics cards...especially trure for 8800gtx... having said that it is always better to have good powersupply...go for any good branded smps that cost around Rs.1500.
10-12-2006, 03:37 PM
The High 5 Flyer
Can you suggest some, available in New Delhi.
