Old 05-12-2006, 09:51 PM   #1 (permalink)
Fedora User
LEARNER_LEARNER's Avatar
Default Query 4 Hub.
Hi brother,how can i share internet 2 pc through hub.
help me brother,i'm waiting 4 ur reply brother.....
__________
if u can't help me then lock my query.my think was digit forum best but i realiz i'm wrong.
Last edited by LEARNER_LEARNER; 05-12-2006 at 09:51 PM. Reason: Automerged Doublepost
LEARNER_LEARNER is offline
Old 08-12-2006, 01:49 AM   #2 (permalink)
shantanu's Avatar
Default Re: Query 4 Hub.
under two pc lan connection...
connect to internet using you server pc and then connect the other pc by hub and hub to your server and run winxp(if using winxp) network setup by going to network connections in control panel .... follow the steps that follow...
shantanu is offline
