Old 04-12-2006, 03:21 PM   #1 (permalink)
lalam's Avatar
Default A Problem With My Fan
I don't really know what you call that fan present on the backside of the cpu where you join in the main power, SMTP Fan????? Been facing this problem since yesterday. The fan on the backside produces some strange sounds that it normally shouldn't of course i can't write to you how it sounds but it like keeps getting loud and then goes down and sometimes theres no sound. I did open the box up and check if the screw were loose and clean the fan but when i put it back on the problem still exist. So is the answer like i have to shelled some bucks and get a new one?? Suggestions please.........
lalam is offline
Old 04-12-2006, 05:53 PM   #2 (permalink)
ymhatre's Avatar
Default Re: A Problem With My Fan
It generally happens to SMPS of local quality after 3 + years....
The reason behind that is....as the SMPS gets older..more heating issues arises in it..as a result the Fan is forced to rotate @ higher rpms...thus causing more vibrations to the PSU (SMPS).....hence you get sound which exist when fan rotates at higher rpm...Also adding to it...if in case your SPMS screws are not tight....more noise will be produced....
Its totally your decision to purchase a new one...or wait till its dead
All i can do is suggest you a SMPS to fulfill your needs
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 04-12-2006, 06:02 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
i will suggest get rid of ur SMPS ...means sell it and buy new branded one just to save urself frm sudden shock of one day ur PC not starting
wizrulz is offline
Old 04-12-2006, 11:59 PM   #4 (permalink)
lalam's Avatar
It was SMPS! Think i will likely go for a new one! Though i would like to know if i should only be buying the fan alone or do i have to go for the whole box? Now i don't know what that box is called again SMPS Box?
lalam is offline
Old 05-12-2006, 12:30 AM   #5 (permalink)
ymhatre's Avatar
Wait a sec....wait .............. a...........sec.....the whole thing is called...SMPS or PSU.
So its definate that you have to go for whole box( i mean SMPS) if you are changing....
DusT = ME
ymhatre is offline
Old 05-12-2006, 03:01 PM   #6 (permalink)
lalam's Avatar
Thanks hatre for the help!
lalam is offline
