Old 04-12-2006, 02:20 PM   #1 (permalink)
sujithtom's Avatar
Exclamation Non bootable DVD RW Drive-Plz Help
I wanna install some Linux Distros through bootable DVDs i got with a magazine. The prob is that my DVD Writer (Sony DVD RW DW-Q120A) is not being shown in the list of bootable devices in the BIOS. I also have a CD-ROM and probably this DVD RW might have been installed as a 'slave' drive.
Is there any way I can make the DVD RW appear in the bootable list of BIOS? Would it be okay if i plug in the DVD RW's wire into the slot CDROM is plugged in on the mother board?
Plz help....
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 04-12-2006, 02:54 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: Non bootable DVD RW Drive-Plz Help
use the jumper setting to change it frm slave....and then check
wizrulz is offline
Old 04-12-2006, 03:06 PM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
open up ur dvd drive n see its jumper setting........
probably both you dvd n cd rom are slave or master (which wud create conflict).
best solution is put them to cable select and plud the ide cables to bothj of them. reboot n check in bios... be sure to post back whether the problem was solved or not
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 10-12-2006, 06:13 AM   #4 (permalink)
sujithtom's Avatar
Yeah tht was the problem. Both my cdrom and dvd rw has been set as master and HDDs as slaves. Weird config. Are the computer vendors mad?
Anyways I changed it. Now the 2 HDD are Primary master and slave and CDROM and DVD RW secondary master and slave. Just like how it should have been. Its working fine noe. Thanks a million....
