Originally Posted by GeekyBoy
I'm sorry for that but how can you listen from the front panel audio if you haven't connected to the motherboard? There must be some sort of link !!!!
And for the logo: I think you may have to flash the BIOS again with the appropriate logo.
I listen from rear panel. I have to get appropriate front audio panel connector
__________
Here are the fixes they claim about
1. Fixed issue where system can’t enter S4.
2. Fixed issue if User access level is set to limited, user can
still change front panel audio setting.
3. Fixed issue where wrong CPU badge is displayed.
4. Fixed issue where wrong L2 cache is displayed.
5. Updated VBIOS to version 008.050i.057.000
6. Removed early power button check.
7. Added IGD UMA Size item in setup.
8. Fixed IDE Controller disable no function issue.
9. Fixed issue where certain hard drives can't boot.
10. Fixed problem when no PS/2 device is connected.
11. Fixed issue if suspend mode is set to S1 then USB keyboard and
mouse can't wake the system.
12. Fixed issue where certain drive imaging software CD can't boot.
13. Fixed issue where certain drive imaging software can't execute
from a LAN boot environment.
14. Fixed issue where the installation of Virtual PC* 2004 SP1 will
cause system to restart.
15. Changed SATA device string in setup.
BIOS Update Release Notes
PRODUCT: D102GGC2 (Standard BIOS)
BIOS Version 1084
November 10, 2006
