Old 02-12-2006, 10:54 PM   #1 (permalink)
Default processor+mobo combo 4 8k
which is the best processor n mobo combo u will suggest for around 8k
varunprabhakar is offline
Old 02-12-2006, 11:09 PM   #2 (permalink)
ymhatre's Avatar
Default Re: processor+mobo combo 4 8k
AMD 64 3500+ @ 4600 RS
Gigabyte K8N51PVMT @ 3700 Rs
That makes 8300 sadly..
Intel 820 P4-LGA 2.8 GHz 800MHz, 2MB Dual core @ 4800Rs
Gigabyte GA-945G DDR2, Sata 2 @ 3900 Rs
Unfortunately this too goes to 8700 Rs
Plus Intel 8xx series have lot of heating problems....u need to get AS5 along with this processor
It will be wise to go for AMD
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 02-12-2006, 11:22 PM   #3 (permalink)
wot is as5?
and would it b wise to go in for 939 based amd pro+mb
Old 02-12-2006, 11:45 PM   #4 (permalink)
ymhatre's Avatar
No it wont be wise to go for 939 now...
but your budget is too low for going for AM2
if you intend to increase you budget to 11k
then go for
ASUS M2NPV-MX @ 4800RS
AMD X2 3600+ @ 6200RS
AS5 stands for Artic Silver 5 thermal paste from Antec...which challenges to bring your temp by 5 - 10 degree
DusT = ME
ymhatre is offline
Old 02-12-2006, 11:47 PM   #5 (permalink)
deathvirus_me's Avatar
AMD Athlon64 3200+ - 4000
MSI K8NGM2 - 3300
Prices inc. VAT ...
deathvirus_me is offline
Old 02-12-2006, 11:51 PM   #6 (permalink)
i also thought earlier of the gigabyte m/b wid 3500+ pro. will the m/b support overclocking? the thing tht appealed me for dis m/b was nice graphics n v out feature? is this combination worth 4 money as cmpd to am2??
Old 03-12-2006, 12:06 AM   #7 (permalink)
ymhatre's Avatar
X2 always had an edge over 939...
But comparing the combo... and the price tag it got, its not bad to go for it..
But i wuld had still invested 3k more to get me good power in processing
ASUS M2NPV-MX also features same stuff HERE
so think before you go for it..
Im with X2 3600
DusT = ME
ymhatre is offline
Old 03-12-2006, 12:10 AM   #8 (permalink)
will d gigabyte m/b support overclocking? i would have preferd to go in for am2 but price is a very big consideration 4 me. by the way pentium d shud b considered or not??
Old 03-12-2006, 12:23 AM   #9 (permalink)
ymhatre's Avatar
NO....P4..
If you had more budget then offcourse C2D wuld be great..
But currently stick to AMD 939 as budget is restricting you..
yes sure you can overclock it too...but mind well its not that performer as compared to ASUS A8N-E....
so provided you have good PSU ...quality ram...then you culd easly Oc'ed
3500 to 2.3GHz+...
and if you have any trouble in over clocking..then overclock guru( deathvirus_me) is just here to help
DusT = ME
ymhatre is offline
Old 03-12-2006, 12:32 AM   #10 (permalink)
how much does asus m/b cost??
Old 03-12-2006, 12:38 AM   #11 (permalink)
ymhatre's Avatar
ASUS A8N-e cost around 5.2k approx ..not sure of this...but wont cost less than 5k
also make a note..it doesnt have onborad GPU
DusT = ME
ymhatre is offline
Old 03-12-2006, 12:44 AM   #12 (permalink)
thx dear. i think i ll stick wid gigabyte + 3500combo.
Old 03-12-2006, 11:53 AM   #13 (permalink)
Not gigabyte .. get the MSI K8NGM2 one , has some really good options to OC ... u can infact push the 3200+ over 2.4 GHz easily , even with cheap ram modules (just have to be ddr400) ...
Old 22-06-2007, 05:33 PM   #14 (permalink)
Hello friend,
Check this site forBest PC configurations. Also Branded PC V/s Assebled PC, Dual core PC under 15,000 are interesting pages.
Check this site.
www.freewebs.com/abdulmustak/
pricelist is offline
