Old 02-12-2006, 07:44 PM   #1 (permalink)
Default wierd noise
I own a Acer TM 4152NLCi
SInce past few days, whenever I press any on the lower keyboard keys like m, space bar etc I hear a wierd noise from below the keypad something like tak tak, its not the normal tapping noise but something louder from below it i guess near the speakers. any ideas?
another problem is my hard disk toshiba. damn too noisy. since beginning .
help me out
Achilles.Warrior is offline
Old 02-12-2006, 08:39 PM   #2 (permalink)
ymhatre's Avatar
Default Re: wierd noise
Are you sure its from below the keypad....
Its ain't from motherboard speaker na ???
usually...the mother board/cabinet speaker/tweeter make a similar tapping noise when you hold three or more than three keys on keyboard...
So it might have happened that any lower key when pressed...will be forcedly pressing more than two keys at a time and the noise is coming from the CPU
Check the same with a new keyboard...
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 02-12-2006, 09:54 PM   #3 (permalink)
its a laptop mate
Old 02-12-2006, 10:38 PM   #4 (permalink)
ymhatre's Avatar
But same implies to Laptop too...
If you press three or more keys together. you are bound to get the tapping sound...
Get the laptop keypad cleaned by vacuum cleaner @ low power...
DusT = ME
ymhatre is offline
Old 05-12-2006, 09:58 PM   #5 (permalink)
its not the beep sound man its something else. some sorta tapping noise
Old 08-12-2006, 02:08 AM   #6 (permalink)
shantanu's Avatar
look bro you laptop is in a circuit design failure state ... just save your laptop by taking it to service center and show them the trouble:
reason: your keypad is having a circuit failure... and two or more key circiuts have been shorting and it give a fatal procedure break to bios and it give a loud tapping sound......
shantanu is offline
Old 08-12-2006, 02:11 AM   #7 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Thumbs up Re: wierd noise
@shantanu is right take it to a service center as soon as possible!!!
Ambar is offline
