Old 02-12-2006, 01:23 PM   #1 (permalink)
Default Can any 1 give good suggestion
Hello friends,
I have a idea of buying a desktop PC. Which is best either branded or assembled? If branded suggest me some model which features Intel® Core™2 Duo Processor E6600. And give ma suggestion that which of the following would be nice to buy?
Intel® Core™2 Duo Processor E6400
Intel® Core™2 Duo Processor E6300
Thank in advance.
sakthirajesh is offline
Old 02-12-2006, 03:20 PM   #2 (permalink)
assasin's Avatar
Default Re: Can any 1 give good suggestion
If u wanna buya branded PC featuring C2D E6600 den i think u'll hafta get it custom made by Dell,but it'll cost u a lot.Better assemble it.
assasin is offline
Old 02-12-2006, 05:03 PM   #3 (permalink)
ymhatre's Avatar
Intel® Core™2 Duo Processor E6600....offcourse... u will have 4mb of cache
Compared to E6300 and E6400 where u will get 2mb...
also the former one has higher clock rates...but no doubt it will sure cost as twice as E6300...But surely you wont regret buying it
I will suggest assemble....But if you are forced to go for Branded then go for Zenieth. They really do have great C2D models....
And one thing to look out when going for Branded....Make a note of what Mother board they are giving....See the reviews of motherboard...then go for it...Otherwise they might just hand you 945...with many limitations in it..
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 02-12-2006, 05:48 PM   #4 (permalink)
vasulic's Avatar
INTEL D975 XBX board
Kingston 1024MB PC5400 DDR2 667MHz Memory
Samsung 17" SyncMaster 740N TFT Monitor
Seagate 250GB
Sony DVD-Writer 16xD 16x, Dual Layer
Altec Lans 251 - 5.1 HighQ - 90w RMS
Microsoft Keyboard and mouse
Zebronics Platinum 500W SMPS
vasulic is offline
Old 02-12-2006, 08:24 PM   #5 (permalink)
ymhatre's Avatar
@ Vasulic
Does your post in any sense relates to the topic...
He had not asked for any configuration.
Dont drift away the topic
DusT = ME
ymhatre is offline
Old 02-12-2006, 09:29 PM   #6 (permalink)
Default Thank You Guys
Thank you guys for your reply. Can any say how much E6600 costs?
Old 02-12-2006, 10:51 PM   #7 (permalink)
ymhatre's Avatar
16800 Rs here in MUMBAI
DusT = ME
ymhatre is offline
Old 03-12-2006, 03:17 AM   #8 (permalink)
The High 5 Flyer
sam9s's Avatar
Go for 6300 best bang for bucks and if you want OC it to 3+Ghz which become 6600(or better clock2clock comparison) which ofcourse is double the cost. If cost is not much of a concern use the money for a good mobo, ram or a graphic card depending on what you are using your sys primarily for. Cache diff is nothing u might feel unless you are working on loads of multiple applications simultaniously. Trust me I have worked on both.
sam9s is offline
