Old 01-12-2006, 01:15 AM   #1 (permalink)
fff..fire fire...
Binay 007's Avatar
Talking Need a suite for the party
I m thinking to bye either Intel pentium D930 or intel pentium D945 ,Does it support/suite my mobo Intel 915GL-V chipset.
P4 2.93(GHZ) ,256 RAM,LG combo drive ,915GL-V mobo
DLink/intex int. modem
Binay 007 is offline
Old 01-12-2006, 03:22 AM   #2 (permalink)
dissel's Avatar
Default Re: Need a suite for the party
I think not....you can install it in your 915 series of mobo....but pentium D...the dual core processing is only enabled if you have 945 series mobo....it means it actually work as Single core processor.
so you can't get the juice....
Now a days why don't you go for a lowest C2D ?
dissel is offline
Old 01-12-2006, 07:25 AM   #3 (permalink)
vasulic's Avatar
yeah, 915 does not support pentium -d and also not C2D processors.
vasulic is offline
Old 01-12-2006, 09:47 AM   #4 (permalink)
assasin's Avatar
The cheapest Intel mobos dat u'll get for P D now are D-101 and D-102.
assasin is offline
Old 01-12-2006, 11:05 PM   #5 (permalink)
fff..fire fire...
Binay 007's Avatar
Unhappy Re: Need a suite for the party
thx friends
mean i have to buy a new mobo ,,what mobo all of u would like to suggest me in cheap but performence sould be good.
Old 02-12-2006, 01:04 AM   #6 (permalink)
assasin's Avatar
It depends on whether u wud use DDR/DDR2 ram.If u use DDR den buy Intel D-101 else buy D-102.Both deliver good performance.
assasin is offline
Old 02-12-2006, 01:31 AM   #7 (permalink)
fff..fire fire...
Binay 007's Avatar
Smile Re: Need a suite for the party
thx friend
Old 02-12-2006, 08:28 AM   #8 (permalink)
caleb's Avatar
Intel 915GL-V chipset based mobo has only DDR Ram...so if you go for Intel D101Ggc mobo you can use your existing RAM.
But if you go for D102Ggc mobo you will also have to buy new DDR2 RAM
caleb is offline
Old 02-12-2006, 02:08 PM   #9 (permalink)
assasin's Avatar
I think it'll be better if u buy a C2D or X2 based PC.Both will be far better dan Pentium D.
assasin is offline
