30-11-2006, 10:41 PM
Romeo + Lucifer = ME
Setting Up wifi
Me and my friend want to connect our pc n laptops by means of Wi Fi......
He lives about 300m from my house(not crow's flight distance but on road)...
Please can anyone help us how to setup this wifi thing
2.wat all we need ?
3.how much would it cost ?
02-12-2006, 01:52 AM
Re: Setting Up wifi
No replies please help me friends
02-12-2006, 10:46 AM
The Devil's Advocate
Re: Setting Up wifi
u need 2 wi0fi cards 1 for each pc .... they will work in ad-hoc mode .... linksys has these cards not sure abt the prices .... if u live in mumbai go to tata's store 'croma' .... there u will find all the hardware and info abt wi-fi
http://beingmanan.com
02-12-2006, 07:49 PM
Re: Setting Up wifi
wat about some router or something like that?
02-12-2006, 09:20 PM
Hell Sucks!!!
Re: Setting Up wifi
Hey romeo,
there is lesser hope of ur out of box wi-fi workng coz AFAIK the max range of current wi-fi is 300 feet n not 300 mts so jus see if u are in permissible distance then u can surely reply here n we can guide u through
02-12-2006, 09:24 PM
Re: Setting Up wifi
well my frends place is about 300 mts from my house...........if we consider crow's flight distance it would be around 200 mts or less........Now tell me whether ir is possible for me n my frend to connect thru wifi(i know nothin about it apart from its full name)
02-12-2006, 09:26 PM
Re: Setting Up wifi
I would suggest u to first consult it with the one from whom you bought the comp.
If still u have some doubts then post in here again
02-12-2006, 09:29 PM
Re: Setting Up wifi
so i should consult some vendors?
03-12-2006, 01:45 PM
Re: Setting Up wifi
rather than vendors i wud suggest u search thru the net for the hardware that will support ur data ranges coz i dont trust the vendor's kknowledge .... r u in mumbai????
03-12-2006, 01:57 PM
TheSaint
Re: Setting Up wifi
He lives about 300.........
Wifi is not possible, not affordable. You will have to use an airstation, not a simple wireless router. Or worse have interruptors all along the way till his house. Its a crazy idea. Even if you use an antenna you may manage a connection, but bandwidth will be poor. Wait for another year, Wi Max will come in the market.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
03-12-2006, 05:29 PM
Re: Setting Up wifi
Thanx friends....... I guess i will have to drop the idea of wifi for the time being
03-12-2006, 06:06 PM
Re: Setting Up wifi
i doubt most of wat u hv said .... wi-fi can b used in adhoc mode between 2 pcs requiring no router only wi-fi cards in both pcs ... correct if im wrong and if i remeber correctly the cards cost around 1000 a peice .... no airstation and all just direct connection
03-12-2006, 06:35 PM
Re: Setting Up wifi
How much will those cards cost n wat range do they cover?
03-12-2006, 06:45 PM
Re: Setting Up wifi
03-12-2006, 09:26 PM
Re: Setting Up wifi
wifi can be used in adhoc mode. without a router etc. but here we need a range of 300 mts. no adhoc setup will give u that much.
one way is to get a linksys wrt54g, install 3rd party firmware like dd-wrt. and boost antenna power u may need to get better antennas. also ull need pci wireless adapter in one machine.
i friend of mine have got a range of about 1km with this router.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
05-12-2006, 07:13 PM
Re: Setting Up wifi
This D-Link AirPlus G DI-524 Wireless Router gives a range of 400mts costs Rs 3650....
Now can someone will this solve our problem?
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
05-12-2006, 08:55 PM
TheSaint
Re: Setting Up wifi
At a distance of 300 metres??!! :-S
Correct me if I'm wrong!
And we have to assume that both connect through the internet through wired lan or dial up so their wifis are free.
__________
Manufacturer's claim? Has it actually been verified? And how much bandwidth will he get at 300 metres let alone 400 metres?
Reason: Automerged Doublepost
06-12-2006, 01:27 PM
Re: Setting Up wifi
2.wat all we need ?
U haven't mentioned how many laptops n desktops u ppl have that need to be connected 2 de network.. If its just 2 PCs (laps or desks), then u do not need any router or access points.. Obviously u need to hav wi-fi cards installed in both ur PCs.. And there r wi-fi cards that give 500 mts range.. But they r very rare in the market! Try 2 get such cards.. they might offer the most economical solution!
Also, why shud u go for a router, when a wireless access point can serve u'r purpose! They are much cheaper than routers!!
Google - What's that?
06-12-2006, 02:53 PM
#19 (permalink)
Re: Setting Up wifi
we need to connect atleast 2 pc n one laptop(wifi enabled).
Lappy is optional, we basically want both pc to be connected.
Now can u suggest me on the wifi cards we sholud go in for n the access point thing
Sony Vaio CW26FG
