Old 30-11-2006, 09:06 PM   #1 (permalink)
shyamno's Avatar
Exclamation Increse RAM speed
I am using Compaq Presario SR1030IL which supports 266/333 MHz as in the following spec.
http://h10025.www1.hp.com/ewfrf/wc/g...dlc=en&lang=en
But I am having a PC2700 MB RAM which should run at 333 MHz but it runs at 266 Mhz...
I am having FSBRAM ratio 3:4....so by following this it comes out to be
4/3*100=133.33 MHz which comes out to be 266 Mhz effective clock speed.
But by motherboard is capable of supporting RAM at 333 MHz.. so how can I achieve this...
Is there any way to change the FSBRAM ratio...
shyamno is offline
Old 30-11-2006, 11:46 PM   #2 (permalink)
assasin's Avatar
Default Re: Increse RAM speed
Wat speed is it showing in the bios?
assasin is offline
Old 01-12-2006, 11:26 AM   #3 (permalink)
shyamno's Avatar
is the bios it is showing 266 MHz only...
shyamno is offline
Old 01-12-2006, 12:41 PM   #4 (permalink)
assasin's Avatar
Try d ram in ur friends pc and see at wat speed its working.Also try updating ur mobos bios.
assasin is offline
Old 01-12-2006, 04:33 PM   #5 (permalink)
ymhatre's Avatar
hmm is there any other ram installed with this one...
Cuz if any other is installed which is of Pc 2100 then they both are bound to be work at 266 Mhz
Anyway you culd check it through Everest or CPUz
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 01-12-2006, 05:08 PM   #6 (permalink)
shyamno's Avatar
how should I update the bios of my mobo... any suggestion..
shyamno is offline
Old 01-12-2006, 07:29 PM   #7 (permalink)
assasin's Avatar
First install everest and find out what mobo u have (make and model no )
den go to the website of ur mobo manufacturer and search if any BIOS update is available 4 ur model.Else search the HP/Compaq site with ur pc model no.
assasin is offline
Old 01-12-2006, 08:00 PM   #8 (permalink)
samrulez's Avatar
Use mem divider as 333MHz...
Sam :D Rulez :lol:
samrulez is offline
