Old 29-11-2006, 10:28 PM   #1 (permalink)
Default USB error
When i connect my camera (or for that matter, any USB device) via the USB port, i get the error message, "USB not recognised...". I tried reinstalling the USB & camera drivers, but to no avail. Even disabled the power options of the USB ports. Is something wrong with the ports? Will i have to invest in an USB card?
asudevan is offline
Old 30-11-2006, 12:49 AM   #2 (permalink)
kirtan's Avatar
Default Re: USB error
Well if any device is not working then it is just an problem with the USB Port.
Water can flow or it can crash.Be Water my friend.
kirtan is offline
Old 30-11-2006, 01:29 AM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm... I recall someone else had a same problem at OTS (cant find it now though). For him what worked was powering off the system which includes pulling off the power cord from mains (this was suggested by someone I dont recall telling that doing so will discharge any residual current from motherboard ).
You try it too ..
__________
Ugh .. Found a similar thread and here too the switching off mains method is given. Check the link.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
Last edited by it_waaznt_me; 30-11-2006 at 01:29 AM. Reason: Automerged Doublepost
it_waaznt_me is offline
