Old 28-11-2006, 09:58 PM   #1 (permalink)
Ankit Agrawal's Avatar
Default computer hangs
hi friends....
I hav got problem with my internet, as soon as I start my modem my computer ( operating system XP) hangs , It works fine when modem is not on, I hav checked modem on other's PCs and 100% sure it's not problem with modem or LAN as I hav tried other HDD on my PC. So in my opinion it's problem with my new HDD (80 GB). Sometimes it works fine with modem on sometimes not , what exactly the problem is ?????... as I hav to convince while replacing my HDD...
if looks could kill i would me a serial killer.
Ankit Agrawal is offline
Old 28-11-2006, 10:58 PM   #2 (permalink)
Default Re: computer hangs
have you changed your RAM too??
da_tcpip is offline
Old 29-11-2006, 07:03 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
U said thay u system hanged as soon as it is connected to internet.I will suggest u to do full scan with two updated antispyware n one gud updated antivirus.Than d a online scaning at www.bitdefender.com
ravi_9793 is offline
Old 29-11-2006, 10:28 AM   #4 (permalink)
Beware of the innocent
ilugd's Avatar
drivers are ok? try removing the modem from device manager and then turn on the modem. See if windows reinstalls it and works ok.
Life is too short. Have fun.
ilugd is offline
Old 29-11-2006, 12:33 PM   #5 (permalink)
asifsyeed's Avatar
Location: Basically i am from Kishtwar(jammu and Kashmir)but presently i am in New Delhi
Hey you need to update ur system driver and all update in ur system are required.so do the update in ur system and and also if problem still occurs then check out ur hDD and replace that with new one but remember to update ur Motherboard and driver.
asifsyeed is offline
Old 29-11-2006, 11:21 PM   #6 (permalink)
hrushij's Avatar
I think u hv to clean ur modem bcs i hv suffered just like u. After cleaning it, it works nice...............
HHJobanputra
hrushij is offline
Old 30-11-2006, 12:23 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
wht is bcs??
Old 30-11-2006, 12:30 AM   #8 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
bcs => because
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-11-2006, 05:53 AM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
mean physically cleaning ofmodem .But if the modem is under gurantee than better call the service man.
Old 30-11-2006, 07:43 AM   #10 (permalink)
caleb's Avatar
Originally Posted by Ankit Agrawal
hi friends....
If your PC is working fine for all other purposes I don't think there is any problem with your HDD...it is more likely that either you have not installed the correct driver or the driver is corrupt. Follow what ilugd suggested first. But if your PC hangs while running other programs (with the modem NOT being connected) than you can say that your HDD has the problem.
caleb is offline
