| Forum |
#1 (permalink) |
Config : P4 2.8, ASRock Motherboard, 768MB RAM, etc etc. Recent Change : New SMPS Please help!!!!! |
#3 (permalink) |
Commander in Chief
First see if DMA mode is enabled in the properties of the burner. If not, try enabling it.
Second, does this happen with all the media. And are the media reputed or cheap ones?
Harsh J www.harshj.com |
#4 (permalink) |
If u r using Nero 6 Change to Nero 7 becos it has ULTRA BUFFER. it will give u extra speed for writing.
Behind every good computer... is a jumble of wires 'n stuff |
#5 (permalink) |
I'm using Nero 7.....and also Roxio EMC 9... nd the medium is Moser Baer 4x DVD+RWs nd also tried 16x DVD+Rs
But this problem wasn't there earlier... So no possibility of softwares causing the problems.. |
#10 (permalink) | |
#11 (permalink) | |
Commander in Chief
@deathvirus_me - Lol
#13 (permalink) |
Yeah seemingly it is due to DMA problem.
Check in Device manager -> IDE -> properties of primary or secondary Channel... It will show in advanced settings Tab, the current DMA mode. It shouldn't be in PIO mode. post in details of that if you still have problem Cheers, |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
