Old 27-11-2006, 07:34 PM   #1 (permalink)
Default HP , Samsung or LG
Which is better in monitors for
CRT (17") ?
quarkz is offline
Old 28-11-2006, 08:38 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: HP , Samsung or LG
SAMSUNG is doin pretty well in CRT monitor business. I recommend that.
Kiran Kumar R
Kiran.dks is offline
Old 28-11-2006, 08:41 AM   #3 (permalink)
If you want a cheap display which performs well, get a philips 107 something. Last i checked it was 3800 bucks all inclusive. I find its color reproduction better than the sammy 793s.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 28-11-2006, 09:07 AM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Samsung r the rulers for monitors...go fo rthem...they r better in this business
__________
3800---- for 17" inch wala???
wizrulz is offline
Old 28-11-2006, 09:47 AM   #5 (permalink)
Yup... thats how cheap CRTs are these days.
Ch@0s is offline
Old 28-11-2006, 12:42 PM   #6 (permalink)
Alive Again...
satyamy's Avatar
Cool Re: HP , Samsung or LG
Leave HP
rest select from LG or Sam both are fine
__________
__________
but its not Flat
invest a little more n go for 17" Flat
satyamy is offline
