Old 27-11-2006, 02:37 PM   #1 (permalink)
Question which one shud i go for????
hey guys....i am really confused about buying a wireless headphones with mic for my PC.....are these wireless headfones good for PC's???because i use mic a lot....Please answer as quickly as possible and tell me any products and their cost related to it.
asher_friends is offline
Old 27-11-2006, 05:42 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: which one shud i go for????
Wireless ones are good at a short distance, but they lack at quality some times. Get some premium product if you wish to have one.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 06-12-2006, 02:22 PM   #3 (permalink)
Talking Re: which one shud i go for????
thank's bro
Old 08-12-2006, 01:52 AM   #4 (permalink)
Try me
shantanu's Avatar
look out for sony and philips and the other guy is right they loose quality and signals and then you move your head for catching them
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
