Old 25-11-2006, 11:18 AM   #1 (permalink)
WOW... are you?
gsoul2soul's Avatar
Default IPOD battery... Blues !!!
Well... my IPOd is Blue in color, and this nagging thought is slowly starting to make me "BLUE..."
My quesiton is... the 2nd generation IPOD Nano 4GB has 24 hour battery life!!!
Happy as a bird here
But what if after some time (even though 2 years is loong time) say it dies!!!
What will i do then ? I mean "rumour has it that, you cannot change IPOD batteries!!!" (gasps and shocked)
So with proper use (i use max 3 hours a day)... how long will battery last (i mean it's life span... in year)
And impart some tips and tricks on how to maximize the life of my baby !!!
thanks... mike here
gsoul2soul is offline
Old 26-11-2006, 09:08 PM   #2 (permalink)
WOW... are you?
gsoul2soul's Avatar
Default Re: IPOD battery... Blues !!!
okay putting things in a simple format !!!
Can you change the battery in apple IPOD 4 GB? (at apple show room or service center)
And how long is it life span? 1 year ? 2 year ? how many ?
Old 30-11-2006, 11:42 PM   #3 (permalink)
gg_3000's Avatar
Yeah, u can replace iPod batteries at the service centres.. I've been using 20 GB iPod for 1 and half years now.. There's no drastic decrease in its life.. It used to last for 12 hrs in the begining.. Now it lasts for around 11 hrs..
Google - What's that?
gg_3000 is offline
