Old 24-11-2006, 07:54 PM   #1 (permalink)
The Unknown's Avatar
Default What's the solution for this problem?
If I plugin any usb device except my hp all in one, my computer hangs. My freind wanted to scan a picture. I scanned it. He gave me a pen drive to store it. I inserted the pen drive and copied the file. After the file copied, my computer hung.
What could be the problem? My friend says Due to many apps running in the background, the RAM dosen't have some space to support the pen drive. He says I should upgrade my RAM to 512.
My Computer specifications:
Pentium 3 500 Mhz
256 Mb RAM
Windows XP SP2
about 10 apps run in the background.
The Unknown is offline
Old 25-11-2006, 12:07 PM   #2 (permalink)
The Researcher
Default Re: What's the solution for this problem?
The memory, processor and the os are in conflict. You may consider buying a new system. I thought that 500Mhz is P2.
Ramakrishnan is offline
Old 25-11-2006, 06:02 PM   #3 (permalink)
Exclamation Re: What's the solution for this problem?
Ramakrishnan, I don't have a P2. It's P3!
Old 25-11-2006, 07:04 PM   #4 (permalink)
I feel that XP as such may not be very stable when run on old & slow speed PCs like 500MHz CPUs. You may try a clean reinstall of XP and see if it works.
After the hang, when you restart the system, look into the event viewer under control panel -->Admin tools and see what’s the system or application error logged there when system went into hang. That might give you some clues to find / isolate the problem.
How many USB ports you have, does it happen on all ports?
patkim is offline
Old 27-11-2006, 09:00 PM   #5 (permalink)
nilesh ur pc is ineeded P3, coz P3 started from 450Mhz, 500Mhz and so on.
U can also try updating XP with the latest patches and also getting rid of some useless program in the system tray.
harshagarwal is offline
Old 27-11-2006, 09:11 PM   #6 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
U seem to be facing the issue's fixed by the update on this Article but U already have XP SP2 so It seems u have a incomplete / corrupted XP SP 2 installation.
Try updating your USB Controller Drivers, Just do this .. uninstall all the USB Controller devices and drivers from Device Manager ... now reinstall Service Pack 2 for Windows XP
Run Windows Update and update your OS
Now Scan for new hardware from Device Manager and let it install the Drivers.
See if this helps you out ...
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
