| Forum |
#1 (permalink) |
I was previously having 128 MB PC2700 DDR ram,then I added another module of 256 MB DDR PC2100 which makes a total of 384 MB RAM.. Now i want to upgrade my PC by adding a 512 MB DDR RAM... Now please suggest me which type of memory should I buy.. Also can I add my any of the previous module with the new mobule of RAM and which one.. __________ Someone please reply.. Last edited by shyamno; 25-11-2006 at 05:21 PM. Reason: Automerged Doublepost |
#2 (permalink) |
How many slots do you have????
If its 2, then do away with both the sticks and get 1X 512MB stick....@400MHz....and if your mobo doesn't support PC3200 then get PC2700 or 333MHz..module..
Sam |
#3 (permalink) | |
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
#5 (permalink) | |
Suppose I use one 256 DDR 266 MHz and one 400 MHz....and my mobo doesn't support 400 MHz then it will be underclocked to 266 MHz ,,,,, so is there any performance loss because even if a install a 266 MHz instead of 400 MHz then they both will eventually run at 266 MHz.. |
#6 (permalink) |
GUNNING DOWN TEAMS
ya get rid of ur ram and get two 512mb ram of same frequency will serve u better..than existing one + 512mb ram
The moment U stop learning ......u stop improving |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
