Old 24-11-2006, 02:30 PM   #1 (permalink)
ASH_DSG
Posts: n/a
Default Which monitor for high resolution
Hi friends,
I want to know which Monitor(15" or 17" only) will give resolution of 1152x864 or higher at 85hz. or 100 hz. so I can play games at these high resolution and of which company. My current monitor is samtron 15" and it works on 1152x864(highest) at 60hz. only so the game run very slowly and U know the flickering of screen. So tell me which companies monitor 15" or 17" will work tell mei'll be waiting for your reply bye.
Old 24-11-2006, 03:17 PM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: Which monitor for high resolution
Most 17 inch monitors give you that resolution at an acceptable refresh rate of 72-72hz. 60Hz is too low.
Though you will be better off with an LCD...
I'm like a bird... :)
goobimama is offline
Old 24-11-2006, 04:41 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
As I know....u can have variable resolution system only in CRT moniters.In case of TFT moniters,they have a fixed resolution for best perfomance.I always suggest for a flat CRT moniters.CRT moniters ahve only one problem,i.e,they are bulky.
ravi_9793 is offline
Old 25-11-2006, 09:12 AM   #4 (permalink)
Manchester United
abhijit_reddevil's Avatar
Samsung Syncmaster 798MB plus for 1280X1024 @ 75Hz and costs around Rs.5500. I have it.8)
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 25-11-2006, 10:02 AM   #5 (permalink)
^^Whatta load of crap... according to specs it only does 68Hz @ 1280x1024 which means u are limited to 60Hz .
http://www.samsung.com/in/products/m...Specifications
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 25-11-2006, 10:16 AM   #6 (permalink)
Manchester United
Do you have anything better in that price range?
Old 25-11-2006, 10:18 AM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
try HP mx705.
Its really good.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 25-11-2006, 02:21 PM   #8 (permalink)
Manchester United
Originally Posted by s18000rpm
try HP mx705.
Its really good.
What is the price? This has also the same max resolution as Sync master 798MB plus. So what's new if it is more expensive?
Old 25-11-2006, 02:26 PM   #9 (permalink)
Just spend a bit more and get a 15" LCD... same viewing area as a 17" CRT and no refresh rate issues to worry about. Should be around 8 grand.
Ch@0s is offline
Old 25-11-2006, 06:03 PM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
i reccomended this coz, i'm using it for nearly a year now without any complaints.
Its Clarity is Fantastic & Radiation thing is very low.
I play games nearly 4 hours straight & have no complaints of eye strain...
btw are there 20" - 21" CRT monitors ???
