Old 24-11-2006, 09:39 AM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default problem with combo drive
dear friends i want to know that why my combo drive could no detect data dvd at once, after opening nd closing the drive 2 to 3 times, then only it detect the dvd but in my dvd writer the same dvd it detect at once, only in the combo drive it happen, but no problem with cd.... plz help me with a solution. If i run a lens cleaning disc in the combo drive will it do?
gau_pppu is offline
Old 24-11-2006, 10:08 AM   #2 (permalink)
why need title?
bharathbala2003's Avatar
Default Re: problem with combo drive
it might work after cleaning the lens.. as that could only be the possible problem..
bharathbala2003 is offline
Old 24-11-2006, 10:45 AM   #3 (permalink)
kirtan's Avatar
Faulty lens i guess.Use a lens cleaning CD to clean the lens of ur drive.
Water can flow or it can crash.Be Water my friend.
kirtan is offline
Old 25-11-2006, 09:26 AM   #4 (permalink)
gau_pppu's Avatar
Is it true.! that using a lens cleaning disc will harm the lens,,,,, what type the lens cleaning disc should i use!
gau_pppu is offline
Old 25-11-2006, 09:32 AM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
Using the lens cleaner doesn't damage the lens, provided ou don't use it too often. Philips lens cleaner is a good one. Use the clening liquid provided with it. Cleaning it once can keep it running for a year or so.
Nokia N86 8MP
Lucky_star is offline
