Old 23-11-2006, 11:26 PM   #1 (permalink)
Default booting from external hard disk
I have an external hard disk attached to my computer. it is 40 GB using USB
I wannt to know if it is possible to install the XP on the external OS and use it as a normal hard drive ?
desijays is offline
Old 24-11-2006, 01:17 AM   #2 (permalink)
gg_3000's Avatar
Default Re: booting from external hard disk
oh yeah.. u can do it.. u just need 2 set it as the 1st in boot order of ur BIOS!
gg_3000 is offline
Old 25-11-2006, 01:22 AM   #3 (permalink)
Eazy's Avatar
I tried to make XP run off an external HDD in a USB2 case but was not successful. Now I have an eSATA external case and this case boots XP perfectly and at full speed of the SATA II HDD as it runs off a SATA connector on the motherboard. I get 62MB/s data transfer rates with this eSATA case.
Eazy is offline
Old 25-11-2006, 08:58 AM   #4 (permalink)
caleb's Avatar
?I wannt to know if it is possible to install the XP on the external OS and use it as a normal hard drive ?
I'm told it can b, so I'm trying it on 2morow with vista on 1 usb hdd & ubuntu on another...will let u know on sunday night how it went.
caleb is offline
