Old 23-11-2006, 02:11 AM   #1 (permalink)
Exclamation broken thumbdrive
hi, i have a 64 Mb thumbdrive. it contains imp. data, however it got broken from the point where it is inserted in USB port. the connector is completely broken. What can be done to recover data.
thanx
choklate_007 is offline
Old 23-11-2006, 09:54 AM   #2 (permalink)
Come get Some
DukeNukem's Avatar
Default Re: broken thumbdrive
yes data can be recovered. but i think and believe you thumbee can be repaired if what you say is true.
and you can do it your self.
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 23-11-2006, 11:29 AM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Can u elaborate on how it be done....if u know.....i had same problem
wizrulz is offline
