Re: Help !!! Usb Device Doesnt Get Recognized
cabinet tin???? Huh, click a picture of your USB ports and show us. The first thing you have to do is go to the bios and make sure the USB controller is enabled. Next, reload your motherboard software. Third, try the USB ports behind the cabinet instead of in front. If the ports at the back work, you have not connected the front USB headers to the motherboard. Read your motherboard manual.
If all of the above dont help, come back here with exact details of your motherboard model, tell us exactly what you tried, and we'll try and help. Current;y, it sounds like you have installed the wrong motherbnoard drivers.
Raaabo
This Forum has rules:
Read them, or else!
Compute Rig: Phenom II X6 1090T | Crosshair IV Formula | 8 GB HyperX DDR2 | XFX HD 6850 | 2 x 300GB Velociraptor (RAID 0) + 1.5 TB Barracuda | Win Pro 64
HT: Denon 1912 | Jamo S608 HCS 3 | Jamo Sub 300 | PS3 | TataSky+ HD | Philips 32PFL5609/98
ICE: Sony Xplod DSX-S100 | Sony Xplod XM-GTX6020 | PowerBass S-12 | 4 x Blaupunkt IC (doors) | 2 x Alpine SPS-609 (rear-mounted)
Guitar Rig: Slammer CT 212 Metallic Red | Yamaha Pacifica PAC012 | Line 6 Pod X3 Live | Beta Aivin MX 30 | Marshall MG 15 CD | Korg ToneWorks AX100G
