Old 22-11-2006, 10:05 PM   #1 (permalink)
:-o
aakash_mishra's Avatar
Exclamation Comp restarts on inserting CD
Hey guys I have got a strange problem...........
When I insert any CD or DVD in my DVD ROM my comp gets restarted
I am having LG DVD ROM...
www.amiable.in
aakash_mishra is offline
Old 22-11-2006, 10:18 PM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Comp restarts on inserting CD
Check the cables and the connections.Clean them. Clean the lens too. Restart in safe mode and see if it happens again.
Nokia N86 8MP
Lucky_star is offline
Old 22-11-2006, 10:29 PM   #3 (permalink)
Kiran.dks's Avatar
I think the problem is in Drivers. Reinstall and update drivers of CD Drive.
Kiran Kumar R
Kiran.dks is offline
Old 23-11-2006, 07:00 PM   #4 (permalink)
:-o
@Lucky_star
I did all that before posting it in forum but no effect it was the same. Even I have changed its Data Cable.
@kiran.rkk
Where I can get its update.......
www.amiable.in
Old 23-11-2006, 07:44 PM   #5 (permalink)
Kiran.dks's Avatar
Checkout these links:
http://us.lge.com/support/download/search.jhtml
http://www.opendrivers.com/categoryc...-download.html
Kiran Kumar R
Old 24-11-2006, 10:47 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Y dont u try a full scan of ur computer.
ravi_9793 is offline
Old 24-11-2006, 03:25 PM   #7 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Wth ..?? There is no such thing as CD / DVD drive driver .. Drivers are needed only in Win98 or 95..
@Aakaash: Did you try disabling CD Autorun feature from the drive..?
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 24-11-2006, 04:28 PM   #8 (permalink)
:-o
Well I don't think disabling Autorun would do something........
As in inserting any type of CD or DVD my comp restarts
As far as your question is concerned I haven't tried that yet.....
www.amiable.in
Old 24-11-2006, 06:07 PM   #9 (permalink)
Kiran.dks's Avatar
@it_waazn't me..
No such thing like Drivers!!! What are you telling? All hardware devices require drivers for interacting with OS. There is no exception for CD/DVD writers. May it be Windows 98 or XP, device driver is a must. Check out the pic....
Kiran Kumar R
Old 24-11-2006, 06:19 PM   #10 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
What IT_WASNT_ME said is ri8 for WIN XP and do not remember for win98 ....one has never to install sperate drivers for CD/DVD roms.....atleast i never did that ........It is automatically done by WINxp OS......
wizrulz is offline
Old 24-11-2006, 07:30 PM   #11 (permalink)
:-o
Well I think we don't need to install any driver in 98 too....for CD/DVD roms
@it_waaznt_me
The prob is still persists
www.amiable.in
Old 24-11-2006, 07:37 PM   #12 (permalink)
What I meant was you dont have to install seperate device drivers for CD Rom/ Dvd Rom / Floppy / Hard Disk . Try finding device driver for CD Roms / DVD Roms .. And tell me what you get ..
@ Aakash : You mean you've disable Autorun and the problem still persists .. Hmmm .. Could you post a HijackThis logfile of your system ...?
Old 24-11-2006, 07:59 PM   #13 (permalink)
:-o
Talking Re: Comp restarts on inserting CD
Are you suspecting for virus or any other kind of trojen or other activity. I use AVG and that too is updated daily and I use Kerio Personal Firewall
www.amiable.in
