Old 22-11-2006, 06:06 PM   #1 (permalink)
Default tell the better one
i m going to buy a dual core, which is better AMD or INTEL, budget 60 k , 512 mb ddr2 ram. shoul i go for dell or lenovo is this ok
Processor, operating system and memory Processor type
AMD Turion™ 64 X2 Mobile Technology TL-50
• 1.60 GHz, Level 2 cache 256 KB + 256 KB
Operating system installed
Genuine Windows XP Home Edition
Upgradability
Windows Vista Capable PC
Product note
Not all Windows Vista features are available for use on all Windows Vista Capable PCs. All Windows Vista Capable PCs will run the core experiences of Windows Vista, such as innovations in organizing and finding information, security and reliability. Some features available in premium editions of Windows Vista - like the new Windows Aero™ user interface - require advanced or additional hardware. Check www.windowsvista.com/getready for details.
Standard memory
1024 MB
Memory type
DDR2 667 MHz
Memory layout
(2 x 512 MB)
Maximum memory
Supports up to 2 GB DDR2 memory
Internal drives Internal hard disk drive
100 GB
Hard disk controller
SATA Hard Disk Drive
Hard disk drive speed
5400 rpm
Optical drive type
Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
System features Memory card device
5-in-1 integrated Digital Media Reader for xD, Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro
Modem
High speed 56K modem
Network interface
10/100 LAN Ethernet integrated
Wireless technologies
Intel® PRO/Wireless 3945ABG 802.11a/b/g Integrated WLAN
Wireless capability
Bluetooth® wireless networking
External I/O ports
1 VGA port; 3 USB 2.0 ports; 1 IEEE-1394; 1 RJ 11 modem connector; 1 RJ 45 Ethernet connector; S-video-out; 1 Stereo Headphone, 1 External microphone; 1 Expansion port for xb3000 expansion base, 1 AC adapter
Expansion slots
One ExpressCard/54 slot (also supports ExpressCard/34)
Display size
15.4” WXGA High Definition BrightView Widescreen
Display resolution
1366 x 780
Video adapter
NVIDIA® GeForce™ Go 6150
Video RAM
Up to 128 MB shared video memory
Control panel
Music and DVDPlay buttons
Internal audio
3D Sound Blaster Pro compatible sound 16 bit integrated
Speakers and microphone
Altec Lansing® speakers
Keyboard
Next Gen full size mobile keyboard
Pointing device
Touchpad pointing device with 4-way scroll
Power supply type
65 W AC Power Adapter
Dimensions / weight / warranty Weight
2.65 kg (5.84 lbs)
Dimensions (W x D x H)
25.7 cm (W) x 35.6 cm (D) x 4.0 cm (H)
Package dimensions (W x D x H)
415 x 164 x 350 mm
ankur1234 is offline
Old 22-11-2006, 09:15 PM   #2 (permalink)
kumarmohit's Avatar
Default Re: tell the better one
The best is Intel Core 2Duo.
But wat is your budget and what are other system specs u lookin for?
kumarmohit is offline
Old 22-11-2006, 09:17 PM   #3 (permalink)
Tech Geek's Avatar
go for the intel C2D E6700
It rocks
Tech Geek is offline
Old 22-11-2006, 10:49 PM   #4 (permalink)
overclocker's Avatar
My opinion is same, go for Intel Core 2Duo.
overclocker is offline
Old 22-11-2006, 11:14 PM   #5 (permalink)
nishant_nms's Avatar
If u can get core2duo then nothing beats it else go for AMD
nishant_nms is offline
Old 23-11-2006, 02:08 PM   #6 (permalink)
aryayush's Avatar
Tell us your budget and have you bought everything else already?
aryayush is offline
Old 23-11-2006, 02:22 PM   #7 (permalink)
Sup' dude, Sup'
go for core2duo
ambandla is offline
Old 23-11-2006, 04:08 PM   #8 (permalink)
deepak.krishnan's Avatar
Intel Core2Duo for sure. But it is expensive.....
.dk
deepak.krishnan is offline
