Old 22-11-2006, 12:40 PM   #1 (permalink)
Maverick340's Avatar
Default PC Freezing , and not becasue of the winter !
Well of late my PC has been constanly freezing. Now i am not sure if you are familiar but if u listen closely ( very ) you can hear a faint chk noise evrytime your PC restart normally . Well everytime before freezing i got that noise. I feared a read/write errr and scanned my pc using HDtune (http://hdtune.com) and also performed scan disk. I didnt get any error so i have ruled out Hard Disk problem . After a little more experimenting i realized that i get this erro everytime a pirtivular scratched CD is there in my CDROM . Now i removed the CD and booted and i dont see it freezing ( else i wont be typing this ) . So i now think my CDROM is at fault .. ( I have been suspecting the darn thing for a while now ! )
So help me out because i sometimes fear a prob with the mobo .. which could spell my death ( eek !) ..
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 22-11-2006, 01:21 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: PC Freezing , and not becasue of the winter !
It's pretty clear that problem is in CD when you experience problem only when u insert bad quality CD. Unreadable CD's when inserted tends to freeze the system. This is a known fact. Just avoid those CD's, otherwise you would end up damaging ur CD drive.
Kiran Kumar R
Kiran.dks is offline
Old 22-11-2006, 04:25 PM   #3 (permalink)
Well interestingly it does freeze sometimes when it CDROM is empty
PSpwned
Old 22-11-2006, 04:55 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
c if something at Pc Freezes All The Time helps u
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 30-11-2006, 09:00 PM   #5 (permalink)
Confirmed : Its because of my CDROM ..
Now could it be because it have connected it somewhere wrong.. naah not that dumb !
PSpwned
