21-11-2006, 03:36 PM
The High 5 Flyer
OC Issues
ehm!!!ok I know sounds repetative. OC issue but no other way except to start a new thread for this one.
Ch@0s I would be looking specifically for your openion. Ok my specs C2D 6300 ASUS P5B Delux Wifi. 800Mhz 1 GB Transcend RAM. Earlier I had corsair 667. Now I dont know where the problem lies......initially with 667 I was able to OC my C2D to 2.5 i.e. 360 FSB and my ram was running at 720, with Vmem at 2.00v, no changes in the Vcore. Ratio was 1:1 as usual. I was impressed on the OC capability of the ram. I wanted to cross 3 Ghz mark, so obviously the first bottle neck was the ram. I was in a mood to go for corsair again,Then some how on chaos advice I got the transcend 800 Mhz. Checkout this discuession if people are interested.......
Good RAM for Core 2 Duo
Corsiair any how was 3500 bucks expensive than Tran. So I got tran. Now even with an 800 Mhz I cant cross same 2.5 Ghz, 360 FSB. My Transcend is running at mere 720 with Vmem at 2.05. 0.05v more then what corsair was getting and trans is not even running at its normal capasity i.e. 800 Mhz forget about OC and crossing 800. My system wont boot the moment I increase my FSB from 360. I have updated the Bios. No changes. I have seen people crossing 3 Ghz mark with the same specs. But NO ONE with Transcend. Check out below forum and an article..
http://www.xtremesystems.org/forums/...=106685&page=2
http://anandtech.com/mb/showdoc.aspx?i=2860&p=7
The same anandtech is using Geil PC2-6400 800MHz for OC benchmark for which Ch@0s forwarded me the following article recomending Transcend.
http://anandtech.com/memory/showdoc.aspx?i=2862&p=2
Ok here is another review what people have to say when I discuessed Transcend on another forum....
"As for your ram, Transcend has little to no reputation in online enthusaist circles so I am still not sure of two things. One, if the memory you have actually has Micron D9 ICs, as they could might have used them in the 667MHz memory and used different ICs in their 800MHz memory and two, whether or not the review samples Anandtech reviewed are representative of their product line and therefore not cherry picked. "
Anyway now I need solution. Some say its the powersupply if not the RAM. I have a 400 W Zebronics PSU. coz everything else is same. My bios is updated. And FSB:RAM ratio is 1:1 as well. Where is the damn problem .............all you techie guys out there need some help here.......
21-11-2006, 03:55 PM
Re: OC Issues
First see what the RAM can do at 2:3(FSB:RAM)... make sure latencies are at 5-5-5(4-4-4 might also work) and vdimm is arnd 2.2V. Could you tell me what latencies you have set in the northbridge config? Personally I've seen 4 sticks of transcend 667 and all of them did 800MHz 4-4-4 at around 2.1V.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
21-11-2006, 04:09 PM
The High 5 Flyer
Re: OC Issues
Originally Posted by Ch@0s
First see what the RAM can do at 2:3(FSB:RAM)... make sure latencies are at 5-5-5(4-4-4 might also work) and vdimm is arnd 2.2V. Could you tell me what latencies you have set in the northbridge config?.
Well my latenciey is set to 4-4-4-12. Check out the snapshot.
I will try changing to 5-5-5 with Vmem to 2.2 when I reach home today. I am in office now and would report back.
Could this mean that the person was right when he said Tran might have used D9 chips in 667 and not in 800. Man I would go for a jolt if that is true. Is there anyway to check that.....the D9 Chips.
21-11-2006, 04:11 PM
Re: OC Issues
^^Quite possible but it should atleast do what its rated at... 800 @5-5-5 at 2V i think. Try the 2:3 ratio to be sure that the cpu is not a bottleneck. What is ur vcore?
21-11-2006, 04:14 PM
The High 5 Flyer
Re: OC Issues
I have tried changing my Vcore : 1.40 to 1.47. Does nothing, makes no difference. Havent gone beyond 1.47 to be safe........BRB.
21-11-2006, 04:17 PM
Re: OC Issues
Its quite possible that ur cpu is hitting a wall... as i said try the 2:3 ratio and see where you get to.
21-11-2006, 04:28 PM
The High 5 Flyer
Re: OC Issues
mmmm would try that out today and would report back.......
24-11-2006, 10:36 PM
The High 5 Flyer
Re: OC Issues
OK sorry to have replied late. Ch@0s. I tried that. I dont think my mobo has an option to manually tune the Timing. I dont know how to set it to 5-5-5. Coz correct me if I am wrong for 2:3 the RAM should start at 400 Mhz, but with FSB starting at 266, I dont have the option of setting up my memory below 533. So I am always left at 1:1. Am I doing something wrong, can you help me understanding how to set the timing at 5-5-5 i.e 2:3. I have the same board as yours.
Man I feel so envy of those crossing 3 Ghz. Some of them are beyond 3.6 with water cooling. I wish I can reach there, I was even wondering what options we have for water cooling in India, but DAMN I am not even crossing 2.5 Ghz. I dont know maybe I should have gone for corsair. Are you sure its not the power supply, coz many of the other forums guys said a 400W PSU is just at the border line plus you need to have atleast 24A under 12+ volt. I have 20A listed there. I dont know.......n number of options. Your move buddy.........
25-11-2006, 01:52 AM
Re: OC Issues
You have a P5B Wifi right? It has all those controls... look hard enough. The timings are in "NorthBridge config"... disable timings by spd and set to manual and the actual timings will show up. If you are running the ram with SPD timings enabled (which is obviously the case since you don't know where to look for it), there's no way you can overclock. My CPU fails to boot beyond 333FSB with timings by SPD and with manual timings, it manages to run superpi at 443FSB LOL. Its simply a timings problem... set it manually to 5-5-5-15 and it'll work easy at higher FSB.
Also I know that you can't set ram below 533 but you can atleast set it to 800 and see if it boots with FSB at 266... if its 800 rated ram, it should boot.... but as before, you need to manually set the timings.
BTW 533 = 1:1. 667 = 4:5, 800 = 2:3 and 1066 = 1:2.
28-11-2006, 11:53 AM
The High 5 Flyer
Re: OC Issues
I got I got. Yea its kinda hard to find. but I got it, and the good new is it worked atleast with 401 FSB. Booted easily. Thanks buddy you are the one.
Snaps just for the sake.
I am gonna try pump up the FSB to 430 try crossing out 3 ghz. Will come back soon. Thanks again. My mem is atleast working at 800. Thats a huge relief.
__________
Ok...I was able to cross 3 Ghz with ease.No problem at all just raised the FSB to 429. I guess I can even try lowering down the voltage since its the timing that was an issue. Thanks again chaos for solving it out. Snaps again...
At 3 Ghz its blazing fast. Leme put it to some good multiple stresses, just to have a feel as to how good it is. Then I will try pumping it to 3.5 Ghz.
__________
Hi Chaos, just thought to let you know, pumped up the FSB to 450, getting a decent 3.15 Ghz. Any idea about the temp, mine is 50-55 normal and 70-75 under 100% CPU load.
Reason: Automerged Doublepost
28-11-2006, 12:22 PM
Re: OC Issues
^^Thats a bit high... CPU temps should be arnd 60 max for 24/7 use.
08-02-2007, 01:16 PM
Re: OC Issues
I would soon need this thread once I get my 800 Ram.
08-02-2007, 02:15 PM
Re: OC Issues
^^Your 667 will do 800 easily  .
09-02-2007, 11:03 AM
The High 5 Flyer
Re: OC Issues
Get an 800 only if you plan to OC like hell.....like trying touching 3.5 on 6300, otherwise you can get a decent 2.8 or so with 667 as well.
09-02-2007, 01:33 PM
Re: OC Issues
Sam I just got a call from Sai communaction, that the 800 Transcend Ram is now available with him, I am so excited ....................just going to NP to look for cooling solution & get the ram, I surely want to OC but not sure how much as I have never done it.
09-02-2007, 02:18 PM
The High 5 Flyer
Re: OC Issues
That is so nice to hear, even I have to upgrade to 2 GB so was waiting for the RAM. If you do get a decent cooling solution PM me I would be verymuch intersted to have a know how.
How much would you be able to OC is something we cant say unless we try. but with the same config you should be able to reach the point where I am.
Get together the stuff......we will try out then......
09-02-2007, 09:31 PM
Re: OC Issues
Sam I finally got the 800RAM for Rs 7000/- each though he last quoted 6200/- but I had to purchase any how.
Regarding the cooling solution all I could find was coolermaster available at SMC its a water cooled unit for Rs5200/-, I asked for Zalman/artic cooler but no one has them, so probably getting from IT depot or online shopping is the only chance.
Since I got 800 ram now I want to start OC , where do I start, there is asus utility AI Suite > AI booster which has an advance tab for over clocking & saving the profile, what setting shall I start with................I am too new to all this.
10-02-2007, 12:20 AM
Re: OC Issues
Man thats a totally retarded price for value ram  . Screw AI Booster... use manual settings in the bios.
10-02-2007, 11:54 AM
#19 (permalink)
Re: OC Issues
Ch@0s,
yes ram is bit expensive but I needed it so bought that one, AI booster works on auto & manual setting so it does have manual setting option without needing to go to BIOS every time.
I just need some setting values to start with weather I do in BIOS or AIbooster its the same setting.
10-02-2007, 11:49 PM
#20 (permalink)
The High 5 Flyer
Re: OC Issues
Ch@0s,
Dont use AI Booster or another windows utility to OC. Need to go in to BIOS, and yes every time if not successful. Go in the advance settings set the FSB to 266 and ram speed to 533. Right now I am in Banglore and would be there for another month so I dont have access to my system, but I will try helping you out. Ok next lock the PCIE freq to 100 and there is another setting next to PCIE freq I dont remember, you need to set it at 33.33. Then try booting and report.........
RAM is ok not that expensive I got it for 9000 on NOV 2006.
12-02-2007, 08:14 PM
#21 (permalink)
Re: OC Issues
Hi Sam
did that in the bios & booted without problem
fsb-266
Dram-533
PCi-e-100
other -33.33
What next?
Should I follow Ch@0S instructions as u did in this thread or should I go slow step by step
__________
While I was waiting for the answers, I tried further increased 266 to 333 & booted without problem, but the CPU ideal temp went upto 70°C which is too high so I reverted back to 266,
I need some direction guys can you help.
12-02-2007, 09:34 PM
#22 (permalink)
Re: OC Issues
Well if CPU temps increase, you need a better cooler. You should be able to do 2.4GHz atleast on stock cooling. Try reseating the heatsink and maybe get a tube of AS5 as well.
13-02-2007, 11:18 AM
#23 (permalink)
The High 5 Flyer
Re: OC Issues
Hi Sam
fsb-266
Dram-533
PCi-e-100
other -33.33
What next?
mmmm 71, should'nt be that high, considering its winters. Mine is stable at 52,53 at 3.3 Ghz. I presume that your cabbi is not well ventilated, Which one are you using, is the air flow correct, like if you have 2 fans, one should be for inflow and one should be for outlet. Similarly in case of 3 fans 2 should be for outflow........
Ideally next step is you to increase your fsb slowly in steps, like you went for 333 then should go for 340 and so on till are able to boot up, but since your CPU temp is souring high you should not try OC yet. First you need to take care of the temp and I am sure you dont need a cooler just yet. 333 is hardly an FSB boost and you are at a meak 2.3. Get your temp down before we move ahead........
13-02-2007, 05:52 PM
#24 (permalink)
Re: OC Issues
Thanks both of you,
I am using frontech Royal, but I am yet to install the 2 80mm front 'intake' fans, as of now it has 2 rear outflow fans & the intel stock cooler, I will see if I can reseat the heatsink & cooler properly & then try once again, else I have to get to shopping a good 1 CPU cooler, 4 antec 80mm fans & a tube of articsilver 5.
none of them is available locally so may be shop online.
13-02-2007, 06:23 PM
#25 (permalink)
The High 5 Flyer
Re: OC Issues
Thanks both of you,
I dont think you need to reset the stock cooler unless you feel you really messed it while placing............frontech is not known for its airflow quality, still if you have 2 rear outflow fans you need to have atleast one intake fan. Also no need to go for Antec fans they are way to expensive, there are lots of other fans available of decent quality, try for them.
13-02-2007, 06:33 PM
#26 (permalink)
Re: OC Issues
I got Rs 30 fan for the cabinet (Nehru place) but its wire is too small to reach the moobo plug, I dont know if I should cut the wire & extend it or not.
Antec 80mm are available for Rs 400/- each from a vendor in Chennai, since they are better known for being silent I am thinking I will get fe w of them for my cabinet.
You are right the frontech is not known for good cabinet but this Royal model is very gud , 2back fans preinstalled, 1 in zebroncs 400 watt PSU, 1 fan option in side panel, 2 fan option in front panel flowing air over HDD.
14-02-2007, 10:27 AM
#27 (permalink)
The High 5 Flyer
Re: OC Issues
400 for 80mm fan  thats an exorbitent price. I have a zebronics cabbi with 3 80mm fans and 1 120 mm fan. All LED fans plus a Temp display at the front. I got the complete thingi for 2400 including 400W PSU, which I replaced though, but I guess you get the point. Neeway if you can spend why should I have hassels, Antec is THE best, thats true.
You try placing the fans and see the result, report back. We will continue the OC from there.........
14-02-2007, 01:50 PM
#28 (permalink)
Re: OC Issues
That day I saerched for zebronics cabinet but could not find anyone having it in stock those 4-5 days, Nehruplace sucks..............I had some very bad experiences.
I can use local fans but the 2 already fitted in my comp make quite a noise, I have heard that Antec are quite less in noise & have better air throw, thats why I am considering buying these,may be I get 2 of them 1st for intake & see the results.
Can I cut the wire & add extenion in the fan wire as it does not reach the plug on the mobo?
Thanks for all ur time & help,I value that.
15-02-2007, 10:16 AM
#29 (permalink)
The High 5 Flyer
Re: OC Issues
Well even I was not getting the zebronics from nehru place. I had to find the authorized dealer for zebronics myself and give that address to the dealer I was purchasing the system from (Coz my bank was financing it through that dealer so I had no chiose). NP is bad yes but you need to know how to find the right person and the right product, then it is'nt that bad..  .
Yes you can cut the extension, and add the wire, but you gotta to know what you are doing otherwise you will just ruin the fan.
Try out your feasible combination then we will move ahead.......always there to help.....
16-02-2007, 11:27 PM
#30 (permalink)
Re: OC Issues
I today opened the mobo & saw that the heatsink was not fitted properly (nehru place guys suck) I further saw that the mobo is having 4 mm sponje laid between the case & mobo , I called up the guy who fitted all my comp , he said that the mobo was getting "short' so he used it for insulation, & it wont harm it any way.
But I guess it will not let the heat transfer on the other side plus if for some reason the mobo is "shorting" with case I better get that replaced, its a month old mobo & it should not have such problem.
I fitted 2 front fans & 1 rear fan & one in PSU but even then my temp are quite high. IN BIOS it show that fans are not fitted where as I have atleast 1 fan conected on mobo at Ch_fan2 on mobo, (2 are connected from the power supply)how do enable that in BIOS?
