okay the Q comes full circle
and this time with a conclusion !!!
But I need your HELP !!!
Okay as you know I had that
"AGP card Geforce 6800 GT" which had 2 Molex inputs
Now I upgraded my motherboard to an AGP 8x and all... but the computer still hanged !!! (like the previous one, which i blamed on my NIC CARD)
Then... i realised, i have never fully given the two inputs !!!
I always gave power using only one molex
But then I used both... and let's say till no nothing is
FREEZING
So obiviously the TWO input is IMP !!! (even when not playing the GAMES and all
Now my Q is
"The AGP card is clever enough right? It will not just draw tooo much power for nothing right?"
It will only draw power according to it's load right?
Thanks
Mike
PS: I bought a single stick of 1 GB of RAM for my motherboard!!!
Should i have opted for 512 * 2... or is it OK ?
I heard 2 stick give you some more perks... is it right?
im confused (as always)
