Old 20-11-2006, 11:47 PM   #1 (permalink)
Default Change DVD Drive front bezel
I have LG GSA H10N DVD RW Drive, white in color. It came with one additional black bezel. It has two separate parts, front panel for CD tray and rest of the bezel.
I want to replace original white bezel with black one, but not getting how to go about it. Absolutely nothing is mentioned about the same in the manual.
If anyone knows, please help.
Thanks,
patkim is offline
Old 21-11-2006, 10:13 AM   #2 (permalink)
ECE0105's Avatar
Default Re: Change DVD Drive front bezel
Instead of changing the Bezel, which is a Costly process, why don't you try to conceal the drive.
Push the drive back in, and then use multiple layers of double-sided tape on the Drive Tray and on the Eject button.
Remove the Side tabs on the plastic things on the Cabinet that originally cover the slots for the drives.
Put that on the drive and it is concealed.
I have done that after checking a few forums on the net and it works fine.
Most of my frnds are not sure wether I have a drive at all.
Wish I had a few Pics to show u....
ECE0105 is offline
Old 21-11-2006, 10:44 AM   #3 (permalink)
aryayush's Avatar
What are you talking about! Concealing the drive is not what he is looking for and concealing it makes it very cumbersome to eject anyway. And how is changing the bezel costly? The extra bezel is bundled with the drive and you just have to pop out the default one and clip on the new one. Unless you pay someone to do this, it won't cost you a single buck!
patkim, I am sorry but I don't now how to change the bezel. I have a Sony DVD-RW drive which came with an additional bezel too, but I never bothered changing it.
aryayush is offline
Old 21-11-2006, 04:06 PM   #4 (permalink)
ECE0105's Avatar
Exclamation Re: Change DVD Drive front bezel
Never heard of it... I have bought a number of drives, for myself and my friends and never got an extra Bezel.
@PATKIM It is not too difficult to change the Bezel.
Open the Drive Tray and remove the Bezel by pressing the Side tabs. Remove the Outer part of the tray by pressing the plastic tabs underneath.
Once done, the Bezel would come out easily. If you have the extra faceplate as Aryayush has informed, You can place them in easily.
ECE0105 is offline
Old 21-11-2006, 07:00 PM   #5 (permalink)
Yes, the drives often come with extra bezel. At least that's what I found with LG GSA H10N white colored drive.
However I felt that the white colored drive in black cabinet also looks quite nice!
Thanks for your suggestions. Yes eventually I was able to change the bezel and CD tray faceplate. The difficult and a little careful part was changing the CD Tray faceplate. I found that it was inserted from top and was held in place by three notches at bottom side of the CD tray. I put a paperclip in the gap between the cover and notch from beneath the CD Tray and slowly pushed it slightly away (forward direction) to unlock it from the notch. When done from either ends, the CD tray faceplate could be pulled up and removed. However had to hold the CD tray with other hand to prevent damage or avoid excessive pressure on it. Bezel could be removed by pressing the side notches and pulling it forward.
I am however a little surprised that the DVD RW manual does not talk anything on how to change the bezel.
patkim is offline
Old 22-11-2006, 07:10 PM   #6 (permalink)
ECE0105's Avatar
Good Work dude... Finally u got the problem solved...
I guess other ppl who would like to change the face plate for their Optical Drives now know whom to get in touch with....
ECE0105 is offline
Old 22-11-2006, 08:05 PM   #7 (permalink)
optumsprime's Avatar
Cool Re: Change DVD Drive front bezel
Thanks Bro
C2D E6600
ASUSP5W DH DELUXE (975 CHIPSET)1GB DDR-2 800 MHZ KINGSTON
XFX 7600 GT DDR-3
500 GB HARD DISK WD
ZEBRONIC CABINET 550 W SUPPLY
19 Inch CRT FLAT SAMSUNG
SONY DVD WRITER
optumsprime is offline
