Hi guys.I have a problem.When i start my pc there is a beeping sound.This sound continues till i shutdown the pc.The pc runs fine though.In the bios it shows that the cpu fan is not working(0 RPM).How to fix this?
Possibly you have placed the fans connector on the wrong header on mother board. It should be placed on the one marked for the CPU FAN. First check visually that the CPU Fan is actually rotating.
