19-11-2006, 03:48 PM
19 inch LCD monitors.(Widescreen and Normal)
Dude Version.
I wnt 2 go 4 a 19 inch LCD monitR , frm Samsung , Viewsonic o BenQ.
cn any1 GIV me som Dtails bout whch iz d best 1 & also d cost.
I tink I wnt 2 go 4 BenQ FP92W. iz DIS a gud monitR. wot iz itz cost.
Budget 15k.
Normal Version.
I want to go for a 19 inch LCD monitor , from Samsung , Viewsonic or BenQ.
Can anyone give me some details about which is the best one and also the cost.
I think I want to go for BenQ FP92W. Is this a good monitor. What is its cost.
Budget 15,000.
19-11-2006, 05:09 PM
Re: 19 inch LCD monitors.(Widescreen and Normal)
i got my Samsung 940bw for 15500. its a nice monitor for the price.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
19-11-2006, 05:31 PM
Myself using Viewsonic VX922. 2 ms response time (heard to be the lowest) and very good performance. Cost me 17.5K.
Absolutely no Dead or Hot Pixel.
V.Prem Kumar
19-11-2006, 06:02 PM
Thanks for the reply you two.
Samsung 940BW fits my budget. Is it widescreen.
I have two systems PIII and Core 2 Duo. One system contains documents and the Core 2 Duo I use is for video and image editing. I will not be using these systems simultaniously.
My query is can I connect a LCD to my PIII system.
19-11-2006, 06:30 PM
Samsung 940BW should be around 14800/- & uses both analog & dvi cable to connect.
Yes you may connect to ur P3 system but its like under utilizing this LCD, best is to buy a graphic card with DVI port & support of custom resolution 1440x900, for ur cure2duo & then fire up the screen with best graphic performance.
Samsung 940BW will make u happy.
19-11-2006, 07:01 PM
Samsung 940bw isnt the best of the LCD 19" monitor trust me there r better infact much better option available then this one,u'll find so many reviews in which people literally curse this MODEL,eva in the last months chip lcd review it has got juz 2 ou of 5.dont go for Benq as there is nothin special bout it at the same time service in india is trully pathetic.
better get urself ViewSonic® VA1912w(WIDESCREEN) 8rms for 14.5k or ViewSonic VG1921wm(WIDESCREEN) 5rms,but no DVI output- for 15.5k(not sure)..these 2 models frm viewsonic are far better then Samsung 940w.CHEERS
19-11-2006, 09:55 PM
Care to share reasons for that statement as I am looking forward to buy this one.
How about the service? Samsung has far more service centre & viewsonic service is provided by HP india.
19-11-2006, 10:23 PM
if you can get viewsonic then get one or else samsng 940bw is pretty decent
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
19-11-2006, 10:25 PM
im using 940bw and it seems to be a good monitor. havent had any probs till now.
19-11-2006, 11:10 PM
Hey does HP really provide service to viewsonic models...???
19-11-2006, 11:13 PM
Yes it does & also for Toshiba notebooks, but my experience with HP service for printer has not been a good one.
19-11-2006, 11:33 PM
1-Samsung has got 138 authorised service centres,120 cities where service are present.
2-Viewsonic has got 112 authorised service centres,102 cities where service are present.
30-11-2006, 04:52 PM
hey, can u spot the performance diff between ur old crt & ths one?
is it too much visible?(annoying?)
want to buy the same.........
So,need ur help..........
please answer frankly....
LIVE LIFE KINGSIZE!!!!!!
01-12-2006, 01:00 AM
Viewsonic simply rocks man.. Heared that it's #1 Brand of Monitors in the U.S.
Google - What's that?
11-12-2006, 04:01 PM
Case Mod - 60% ||||||----
hey can ne1 owning a 19" widescreen temme, hw much can the resolution stretch too..(max resolution)
11-12-2006, 08:35 PM
I dont yet own the wide screen but have tested 2 & buying the samsung 940B, its max will work at its native resolution 1440x900.
12-12-2006, 12:42 PM
whics is betta 19 wide or normal 19?
12-12-2006, 01:03 PM
ne idea bout the 20.1"??
12-12-2006, 03:24 PM
#19 (permalink)
How come both of Samsung's 17" and 19" monitors have the same native resolution ? Can anyone explain ... :S
12-12-2006, 03:32 PM
#20 (permalink)
pixel pitch is going to be different. like in mobiles nokia 6020 and 6230i have near about same screen size but 6020 has resolution of 128x128 and 6230i has 208x208 px. naturly display on 17" will be more crisp due to lesser pitch. 19" with same resolution will just zooming making pixel size a little big.
12-12-2006, 04:42 PM
#21 (permalink)
damn it ... is there any 1600 x 1200 and 19" LCD display ?
12-12-2006, 11:37 PM
#22 (permalink)
The High 5 Flyer
Which of these monitors discuessed are HDCP compliant. Samsung, and viewsonic.
13-12-2006, 12:17 AM
#23 (permalink)
940bw is HDCP ready i think
No idea about ViewSonic ..
