Old 18-11-2006, 06:00 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
The Unknown's Avatar
Question Will a DVD Work?
Will a DVD or Dual Layer DVD Writer work on a computer with Pentum 3 500Mhz, 256MB RAM and OS Windows XP?
The Unknown is offline
Old 18-11-2006, 07:22 PM   #2 (permalink)
varkey's Avatar
Default Re: Will a DVD Work?
yes it will work. i was using it in an almost similar setup.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
Old 18-11-2006, 07:30 PM   #3 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
guess ull b needin an upgrade dude......ull b beter off with a 512mb ram n a faster processor
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 18-11-2006, 08:50 PM   #4 (permalink)
varkey's Avatar
it will be bit slow in burning thts all. in my old machine took abt 11-12 min to burn a full dvd and now in the new mchine it takes only abt 6-7 min.
but anyway it shud work
varkey is offline
Old 18-11-2006, 08:56 PM   #5 (permalink)
gooby pls
Third Eye's Avatar
Yeah you can run it without any problem.
Third Eye is online now
Old 18-11-2006, 09:13 PM   #6 (permalink)
assasin's Avatar
It'll run ok untill u think bout multitasking while writing a DVD.
assasin is offline
Old 18-11-2006, 10:39 PM   #7 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
if time not issue while burning DVD's it should do fine..but then do not try to compare times with other
wizrulz is offline
Old 19-11-2006, 10:40 AM   #8 (permalink)
Still Shining!
Lucky_star's Avatar
Just before clicking the burn button, bring up the task manager, goto processes and shut down all those programs like anivirus, media players, utilities which are eating up the memory, and all those tasks which reside in the system tray. At the end shutdown explorer too. Then, go on to write your DVD. It should go fine by now. While writing leave the computer idle.
In my old system, I used to startup in safe mode when writing a DVD
Nokia N86 8MP
Lucky_star is offline
Old 19-11-2006, 12:18 PM   #9 (permalink)
Talking Re: Will a DVD Work?
Totally Agree with u... Give the MAX system Resources To the Burning ... Best If u could all To it ..
Also Burn @ Slowest speed Possible ... Thats the key to Not to get a Coaster on a Slow system
vinyas is offline
Old 20-11-2006, 09:45 PM   #10 (permalink)
Exclamation Hey! Vinyas, I don't have a DVD Writer.
Don't give me suggestions to how to burn DVD(s) because I was just planning to purchase one. I think ur suggesstions will work bcause I have tried it with Handycam
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/41571-will-dvd-work.html
Will a DVD Work? - Digit Technology Discussion Forum This thread Refback 13-01-2012 06:51 PM
