Old 18-11-2006, 07:41 AM   #1 (permalink)
Smile two monitors
hi,
does any one know if i can connect two monitors seperate to one cpu. if yes how. and what do i need please help.
thanks
jessycherian is offline
Old 18-11-2006, 08:35 AM   #2 (permalink)
Evil Genius
faraaz's Avatar
Default Re: two monitors
I think you will need to have a video card which supports dual output...after that, its a simple matter of connecting the two VGA cables to your monitors and your video card...and then there's mucking around with the advanced display properties settings. Sorry I'm so vague mate, but its not like I've done this personally...only read about it in Digit and stuff.
However...google it up. I bet there's tons of guides out there that tell you how to do it. That...or wait for someone more knowledgeable than me!
Roses are #FF0000, Violets are #0000FF...All of my base are belong to you!
faraaz is offline
Old 18-11-2006, 04:39 PM   #3 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Just connect both the monitors and restart the os. It will be auto detected and then just fine tune the display through your video driver/display setting.
john_the_ultimate is offline
