Old 17-11-2006, 12:49 PM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default want to forward port
how would i know what is my rooter address nd its model no, i had a cable inter net connection, where they donot provide any modem, only a cable wire fit in my lan connection, so if i want to forward a port, then how would i do this............
gau_pppu is offline
Old 17-11-2006, 11:05 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: want to forward port
SEARCH BE4 U POST
Faster torrent speeds(Router-Client Config.)
and i guess as u have cable net conection u mi8 not be using router...ask ur cable wala...
read this also:
http://www.thinkdigit.com/forum/show...402#post347402
wizrulz is offline
Old 18-11-2006, 11:18 AM   #3 (permalink)
shyamno's Avatar
Originally Posted by wizrulz
SEARCH BE4 U POST
read this also:
If any one doesn't have a router (cable connections) then how he may increase his torrent speeds ????????
shyamno is offline
Old 18-11-2006, 11:26 AM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
i am also trying to find the same answer ...as i also have net connection....
wizrulz is offline
