Old 16-11-2006, 10:30 PM   #1 (permalink)
Walking, since 2004.
mail2and's Avatar
Default Mouse: Laser or Optical(cordless)?
Hey guys.
I've been using this basic Logitech Optical Mouse for an eternity. It's starting to age and the pointer goes haywire every now and then(only at the 'smooth' parts of my table). I've tried another mouse(bad scroll wheel) and it works perfectly on my desk. So, it's the mouse, indeed.
So, my question is, should I get a new laser mouse? My budget is around 1k, but I can extend it to 1.5k. I think the iBall Laser Precise mouse is around 600-700, isn't it? Any other laser mice under 1.5k?(preferably cordless. I know I'm stretching it a bit too much!).
Which is the cheapest cordless laser mouse anyways? If not cordless, can you suggest good wired laser mice?
Mumbai, I miss you. :(
mail2and is offline
Old 16-11-2006, 11:36 PM   #2 (permalink)
kumarmohit's Avatar
Default Re: Mouse: Laser or Optical(cordless)?
If you are in gaming or grafics work like photoshop you shud go for the precision of a laser mouse, cordless or corded shud be a secondary consideration.
kumarmohit is offline
Old 16-11-2006, 11:43 PM   #3 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Zebronics RF cordless mouse 1000
ONLY Rs.650 Really!!
But u r Gamer or Graphic deginer go for logitech corded one
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 17-11-2006, 01:16 AM   #4 (permalink)
mail2and's Avatar
Actually, I wanted to go in for laser as I wanted to avoid the issues that I'm currently facing with my optical mouse. BTW, how good are zebronics mice?
I'm not a gamer or a designer.
mail2and is offline
Old 17-11-2006, 01:45 AM   #5 (permalink)
OPTUMS PRIME's Avatar
Cool Re: Mouse: Laser or Optical(cordless)?
Yes Laser Mouse Is Best Go For Microsoft Mouse
I make my own Rules. I set my Own Goals. I follow the path less followed. I am What I Am
DEVIL MAY CRY
OPTUMS PRIME is offline
Old 17-11-2006, 03:10 AM   #6 (permalink)
aquamatrix's Avatar
wh dont you try the genius ergo 525 , it'll come about to 1.5k.
if going for sub 1k mouse iball laser precise will be the best. i am using it and its a gem of a mouse
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
Old 17-11-2006, 11:56 AM   #7 (permalink)
rohanbee's Avatar
Ive been using optical mouses for a long time now!!...
microsoft, logitech, dell...............some wireless one's too........without any major hassle or problems............
Also, use them easily in photoshop and gaming.........
Only problem with the wireless is the battery..........which needs to be recharged after a while...
Considering buying one with inbuilt rechargable batteries and base now...
Quote by Garfield'
rohanbee is offline
Old 17-11-2006, 09:50 PM   #8 (permalink)
royal's Avatar
Smile Re: Mouse: Laser or Optical(cordless)?
Guys, I have been using a HP optical mouse in my office...
While playing QuakeIII, I noticed that if I try to move too fast (near any obstacle) then the mouse does not function properly
But the Logitech ball mouse at my home works well enough
So I was just wondering...are ball mice better than optical ones for gaming ?
However I must admit that I have never used a laser mouse ...
royal is offline
Old 17-11-2006, 11:48 PM   #9 (permalink)
aquamatrix's Avatar
nope a good optical mouse is always better than ball mouse.
Old 18-11-2006, 02:52 AM   #10 (permalink)
Learner
Kniwor's Avatar
i have been using the logitech optical mouse forever, though i change my mouse every 6-8 months, i purchase the same old Rs. 350/- logitech optical mouse, i am not comfortable with other mouse, i got a microsoft mouse last time i had to change mouse, and it's lying around unused, i had to get the logitech one next week.
I game all the time, day/night, and i have never had problem in playing any game, i have never used a laser mouse so my experience might be relative, but optical mouse precision depends a lot on the surface, and ideal surface would be black or any plain color, and not shiny at all, but smooth is good. any shiny surface causes problems, and surface with many colors also causes problems though i dont see a reason. and people tend to blame optical mouse.
So my advice is, if u're going to spen 1k on mouse, again get a logitech one with a similar feel and weight, too light or too heavly will cause u problems.
Kniwor is offline
Old 18-11-2006, 04:42 AM   #11 (permalink)
caleb's Avatar
?I game all the time, day/night, and i have never had problem in playing any game, i have never used a laser mouse so my experience might be relative, but optical mouse precision depends a lot on the surface, and ideal surface would be black or any plain color, and not shiny at all, but smooth is good. any shiny surface causes problems, and surface with many colors also causes problems though i dont see a reason. and people tend to blame optical mouse.
?So my advice is, if u're going to spen 1k on mouse, again get a logitech one with a similar feel and weight, too light or too heavly will cause u problems.
Same thoughts here.
caleb is offline
Old 18-11-2006, 06:50 PM   #12 (permalink)
As Kniwor said, I also feel most comfortable with Logitech and personally I have used this brand only from the very beginning. I have used many other brands in my office. But I wonder why it should be changed every 6-8 months. My present Logitech optical is 4 years old. May be because I don't game.
V.Prem Kumar
janitha is offline
Old 19-11-2006, 03:49 AM   #13 (permalink)
Learner
Kniwor's Avatar
you answered it urself, i dont know if this is just my problem, i am an excessive gamer, and after say 6-8 months, i feel the mouse is getting less responsive, maybe it's the wire, or some precision part inside is moved , whatever it is, i use a cheap mouse so replacing is no problem. i have the money and i can go today and grab a Rs. 1500/- gaming mouse, but i know I'll regret it.
Kniwor is offline
Old 19-11-2006, 10:25 PM   #14 (permalink)
aquamatrix's Avatar
nope you wont.
Old 06-12-2006, 02:30 PM   #15 (permalink)
montylee's Avatar
Genius Ergo 525 is the best bang for buck especially when paired with Stellpad QCK gaming mouse pad.
If u can afford to spend nearly 2K then go for Genius otherwise go for iBall Laser.
Intel Core 2 Duo E6300, Intel DG965RY, MSI 8600GT OC, WD 250GB SATA-II Harddisk, Transcend 1GB 667 Mhz DDR2 RAM, Samsung Samtron 55V, Sennheiser HD485 cans, Zebronics LAVA Cabinet, Zebronics 400W PSU
montylee is offline
Old 06-12-2006, 02:39 PM   #16 (permalink)
filth is me
forever's Avatar
guys , i have an ms optical mouse , can some1 suggest me what surface or pads i shuld use for it, some guys advised gaming pads are always the best , can some1 tell something about these gaming pads and their costs,wuld appreciate it , ty
forever is offline
