Old 16-11-2006, 03:55 PM   #1 (permalink)
rohanbee's Avatar
Default Looking at this wireless router? comments
Im planning to use this wireless router D-Link DL524 Airplus G 802.11g/2.4ghz,
Im going to be using it to configure my laptop and desktop to use the bsnl broadband connection......
Anyone have anything good or bad to advice about this product before i buy....
Does it have good coverage and connectivity?
Are there any disturbance in signal problems?
Is there a alternative you can suggest in the 3k range?
Thanks in advance guys!!
Quote by Garfield'
rohanbee is offline
Old 17-11-2006, 06:47 PM   #2 (permalink)
rohanbee's Avatar
Default Re: Looking at this wireless router? comments
Anyone...........anyone............any info
Quote by Garfield'
rohanbee is offline
Old 17-11-2006, 09:11 PM   #3 (permalink)
pedal to metal
suave_guy's Avatar
you can look for linksys wrt45g wireless router within the same budget
i'm using the same product and i'm completely satisfied by this product and the range is also excellent, software and tech support is also very good...
never been a fan of D-Link, netgear etc.
ENJoy...
your "attitude" is your best friend...
suave_guy is offline
