Old 15-11-2006, 09:00 PM   #1 (permalink)
Default USB PC Camer driver needed
Hello..
Unfortunately, I have no more cd of the webcam I have,
I have similar webcam..
http://cgi.ebay.in/Intex-Night-Visio...QQcmdZViewItem
night vision + with microphone.
If anyone has similar then plz let me know, send it via any free uploading service .
Ricky is offline
Old 15-11-2006, 09:11 PM   #2 (permalink)
aquamatrix's Avatar
Default Re: USB PC Camer driver needed
why dont you just google it
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
Old 15-11-2006, 09:28 PM   #3 (permalink)
buddy.. after doing lots of googleing .. I m here.
.. had installed 4-5 drivers .. not yet a success.
__________
Well.. still looking..
found this.. ---> http://www.intextechnologies.com/download.asp
if it worked then will let ppl know..
else if still anyone has same.. send me driver
Ricky is offline
Old 23-11-2006, 04:55 AM   #4 (permalink)
did u buy intex pc camera night version .....1OOK
i am getting suc ed up with it ...
its useless ...no driver is working in my XP system
please soem one help me tooo...
lajs is offline
Old 30-11-2006, 05:40 PM   #5 (permalink)
Well..
I think this one will work for sure for you..
http://www.MegaShare.com/80369
Ricky is offline
Old 03-12-2006, 09:57 PM   #6 (permalink)
thanks ,.....i wll try it and tell u
__________
hey even this driver is not workign properly with the webcam ...
i hate intex
it suxxx..
did u try it ...was it a positive result !!
lajs is offline
Old 07-12-2006, 05:52 AM   #7 (permalink)
Ha its working and btw, it was provided with INTEX itself !
__________
Arre!
Seems many ppl are in need of driver. ..
its been downloaded 13 times already !
Ricky is offline
Old 14-12-2006, 12:39 AM   #8 (permalink)
If that wont work .
Try .. http://www.megashare.com/84756
Ricky is offline
Old 25-12-2006, 02:04 PM   #9 (permalink)
That one worked with such camera.. !
Ricky is offline
Old 10-06-2007, 01:53 PM   #10 (permalink)
could some1 re-upload it to me plz
Black Joker is offline
