Old 15-11-2006, 07:51 PM   #1 (permalink)
Question Need help buying a PC
Hai everyone,
This is Dilip from shimoga, I am planning to buy a new PC based on Intel C2D processors. My needs are hardcore gameing and as well as it should work fine every app's that I install. Also specify if Intel boards supports any PCI-PCIe cards or it only come with onboard graphics. I saw this months digit mag, but I am still confused on the MB and the CPU, because if they dont match properly every thing goes wrong. Please it's urgent. and also specify some good tv tuner cards(external) Budget is 25K to 30K
dilpedilip is offline
Old 15-11-2006, 10:16 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Need help buying a PC
dude u didnt maintioned ur budget.... ...
there is C2D Extreem with 2.93GHz also Qaud Core is around the corner... so there are many option to chose for unless u give a budget
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 16-11-2006, 12:57 PM   #3 (permalink)
My budget is around 30,000
__________
I have mentioned it now please go through it and specify me a good config
Old 04-03-2007, 05:55 PM   #4 (permalink)
The High 5 Flyer
sam9s's Avatar
Originally Posted by dilpedilip
C2D 6300@3.304 Ghz. ASUS P5B-Delux Wifi. 1 GB Transcend DDR2 800 Mhz RAM. XFX 7800GT, Samsung 940BW 19" LCD, 160x2 Segate SATA II (RAID 0), 250GB Segate IDE, Sony DVDRW, Altec Lansing ATP5
Hai, can you tell me the price of the pc that you have described.
can you give me the individual price tags. I am planning to by a new pc for myself. Also tell me if I can have the AMD processor on P5B Delux and on GA-965P-DQ6(Gigabyte) MB's
thanks in advance
Ok with my config you will definately gonna shoot the budget, so you need to first decide what exactely you would be using your system for. My hardware approx NP delhi price will be....
C2D 6300....~8000
ASUS P5B-Delux Wifi......~10,000
1 GB Transcend DDR2 800 Mhz RAM........~6000
XFX 7800GT........~12,13000
Samsung 940BW 19"........13,14000 LCD,
160 Segate SATA II........~2500
250GB Segate IDE.........~3500
Sony DVDRW.............~2000
Altec Lansing ATP5......Model discontinued.......Go for ATP3 but that is 2.1
TOTAL........................59000
Also include.......Zebronics Cabbie....2300
Powersafe PSU.............................2000
Grand Total..................63300..
Ok now for other queries...no you cannot have AMD either on P5B delux or DQ6. Those are ment specifically for Intel 965 series.........
Now decide your purpose, usage, budget and I would be more than happy to help.....
sam9s is offline
Old 04-03-2007, 06:23 PM   #5 (permalink)
Now that's what I call a complete budget list for your pc. Thanks sam, thanks for your help for now I am going to settle for ASUS P5B, 250 GB HDD, and 256 MB RAM and C2D with 1.86GHz for an exchange of my old one, which has already got Sony DVD RW 170C. That should cut down the budget to around ~22K. Since my father wont allow the budget of 63K I will have to settle for 20K
Thanks for your most welcomed help.
Old 04-03-2007, 06:52 PM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
You are most welcome. BTW you can click on the ballance sign to rep me. That another way of thanking in these forums.....
sam9s is offline
