15-11-2006, 07:38 PM
Urgent
How much does a good 256 MB ram cost, a 40 GB hard disk?
Name the companies also
My budget for these 2 is 3K
Reply fast
URGENT
15-11-2006, 07:50 PM
Re: Urgent
dunno about HDD, but the ram will cost you around 1.5k
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
15-11-2006, 07:51 PM
Re: Urgent
Any good companies for the ram
15-11-2006, 08:05 PM
Tux Fan
Re: Urgent
DONT BUY A 40GB HDD
A new 40gb hard drive will cost you 2300 [samsung] while a brand new 80GB costs 2500 {give or take 200rs on the prices for other brands}.
I suggest you go for a new 10K RPM 80gb seagate/samsung drive for 'bout 2400/2500.
[Even buying a 40 gb HDD will overshoot your budget.]
Ram brands: kingston, corsair.
One 256 strip will cost you bout 1.2K~1.6K.
80GB 10K rpm samsung ------------> 2.5K
kingston DDR1 400mhz 256Mb----> 1.5K
Cheers
Shaunak
Feel free to PM/email me.
15-11-2006, 08:27 PM
Re: Urgent
Thanks for the info shaunak
__________
i am not sure if i wud find kingston, so any other brand of ram
Reason: Automerged Doublepost
15-11-2006, 08:48 PM
bang bang!
Re: Urgent
Go for Transcend DDR1 400mhx 256mb. I think it will cost around 1600-1700.
15-11-2006, 08:55 PM
Re: Urgent
My main purpose for upgrading RAM and Hard Disk capacity is to increase my computer speed. Supposing I just upgrade RAM to 256MB, and retain the 20GB Hard Disk (to save costs), will there be a good increase in speed (if yes, by how much?), or do I HAVE to change my hard disk also to get better results?
IM AS MAD AS HELL!!
Re: Urgent
dont buy 40 GB buy 300 GB
buy 2 GB RAM
u will feel it for buying
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
15-11-2006, 10:44 PM
Re: Urgent
Quote
"I suggest you go for a new 10K RPM 80gb seagate/samsung drive for 'bout 2400/2500."
Is it true? 10K RPM for such a price!
V.Prem Kumar
15-11-2006, 11:08 PM
Re: Urgent
I dont think computing speed depends directly on a HDD`s capacity. One just need to defrag and scan it to get the maximum out of it. But PRM is important so if u r not bothered about space then concentrate on PRM. U can always consider old faithful Seagate for HDD.
As of RAM consider a DDR2 if ur motherboard supports it and go for the maximum considering ur budget. U can consider Hyundai. I am using it for last 3 years and did not face any problem.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
16-11-2006, 12:24 AM
Re: Urgent
omg 10k rpm 80 for 2.5k , are you sure???
16-11-2006, 06:41 PM
Re: Urgent
I have PIII will it support DDR2 ram?
i want to only by ram . suggest one(with brand name and price)
16-11-2006, 06:50 PM
Re: Urgent
nope not ddr2, buy 256 only. transcend or simmtronics will do, no hi fi stuff needed here. and yeah both will cost you around 1.5k
16-11-2006, 07:06 PM
Re: Urgent
Thanks aquamatrix
16-11-2006, 07:11 PM
GUNNING DOWN TEAMS
Re: Urgent
which ram already u have ???decide accordingly which one next to buy
16-11-2006, 07:31 PM
Re: Urgent
I have a 128 one so now i am goin for 256 MB ram
16-11-2006, 11:41 PM
Re: Urgent
Exactly increase RAM first HDD can wait a bit.
17-11-2006, 11:59 AM
GUNNING DOWN TEAMS
Re: Urgent
company and its speed wil also matter ...try getting ram of same company adn speed...i hope u know this
17-11-2006, 07:49 PM
#19 (permalink)
Re: Urgent
How to know the speed of the ram?
