hi,
the series 256,512,1GB is not necessary... you can have RAM how ever you like... no problem with your 768MB.... its fine... if you want to improve the performance of your system then you should upgrade your RAM...
2* 512MB RAM gives better performance than single 1GB RAM...
thank you.
For The World You Are Someone...
