Old 14-11-2006, 09:02 PM   #1 (permalink)
soumya's Avatar
Exclamation 7600 Gs Or 6600 Gt?
I am really confused about the card to go for! What about the 6800 GT too?
I blog at http://windowsxperience.wordpress.com/
soumya is offline
Old 14-11-2006, 10:02 PM   #2 (permalink)
assasin's Avatar
Default Re: 7600 Gs Or 6600 Gt?
if u can den wait for bout 6 mnths.Prices of DX 10 crds will drop by den.Dont buy a DX 9 crd now if u dont need it dat urgently.But ifu do den go for 7600GS.
assasin is offline
Old 14-11-2006, 10:43 PM   #3 (permalink)
ymhatre's Avatar
dont expect miracles .... After 6 months i agree the price would reduce but not by that amount....Also consider about the "INDIA" factor ...
Gyosss..when will PS3 release in INDIA
I would suggest you to go for 7600 Gt rather if u are considering 6800 GT, or else 7600 Gs is just fine for low - medium end gamer
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 14-11-2006, 11:03 PM   #4 (permalink)
1st let dx 10 card release than its prize will drop.......
magnet is offline
Old 14-11-2006, 11:46 PM   #5 (permalink)
soumya's Avatar
Cool Re: 7600 Gs Or 6600 Gt?
i don't wanna invest too much for a dx9 card now. I guess u guys r recommending 7600 gs. Thanks!
soumya is offline
