Old 14-11-2006, 07:59 PM   #1 (permalink)
rohanbee's Avatar
Default which is better wireless or wired?
I was just planning to go wireless on my broadband connection but then a fellow member suggested that a wired connection might be better.........
Give me your comments guys. Would really appreciate.......
Quote by Garfield'
rohanbee is offline
Old 14-11-2006, 08:11 PM   #2 (permalink)
NEXT BILL GATES
mihirvashist's Avatar
Default Re: which is better wireless or wired?
wireless solution is great for connecting computer in a SOHO setup becoz their no hassle of wires...however in ur case you want wireless broadband connection....which though very much possible will give you slow speed when compared to their wired counterparts on relatively higher prices.......
but still if you want high speed then be ready to shed big bucks ....my opinion is that you stick to wired broadband ....i would done that if i were you....
KNOWLEDGE IS POWER!!:-)
mihirvashist is offline
Old 14-11-2006, 08:51 PM   #3 (permalink)
JhonCena's Avatar
I suggest you only wires for broadband
----------> http://www.blogofwebmasters.com/ <---------
WEBMASTERING TUTORIALS, ARTICLES AND MUCH MORE
JhonCena is offline
Old 14-11-2006, 09:42 PM   #4 (permalink)
varkey's Avatar
I doubt whether it would cuase speed probs in Indian broadband lol
any wireless solution will be able to give u 256 or 512 kbps without any probs.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
Old 15-11-2006, 11:30 AM   #5 (permalink)
rohanbee's Avatar
ya th system in my office are all wifi enabled and they seem pretty ok at downloading too....
+ i have the unlimited connection.....so im not bothered about shuting it down,,,,,
Quote by Garfield'
rohanbee is offline
