Originally Posted by assasin
Guys my rig's config is:
AMD Athlon X2 3800+
Asus M2N-MX
Hynix 1GB DDR2 667 (OC to 800)
160 GB WD Caviar SATA II
Asus 6600LE 256MB PCI-E
Bought it bout a month back and i'll buy DX-10 gfx card when d prices drop a little.
My OS is Windows Vista RTM and i play all d latest games.
Sud i upgrade my rig(proccy + mobo) or only upgrading the GFX crd will do?(i hav bout 22k,if i dont hafta upgrade my proccy + mobo,den i'll go for a SONY 17"TFT)
If i dont upgrade now,how long do u think will dis config last???
ur rig is good enough for 5-6 months as long as u dont buy vista as soon as it is launched
ur ram and hdd r good enough for a year+ i'd say
ur proccy is ok but ur 3d card is a little old
id say u invest in a 7600gt (maybe 8600 gt DX 10 version)
but most probably ur proccy will be a bottle neck
as ur budget is 22k i say u wait for vista to be launched (maybe ur budget will increase till then)
& after that invest in a good proccy(maybe 4400+ as its price will come down though x2 is not as good as c2d )but u should also invest in a 3d card at that time
the bottomline is...... wait
i think u should not invest in the tft
which monitor do u have?
