Old 12-11-2006, 09:49 PM   #1 (permalink)
soumya's Avatar
Default Which motherboard should i opt for my core 2 duo 6600?
I am quite confused. i guess ASUS P5B, Intel DG965RY and MSI 965 neo are quite good. What do you guys suggest?
soumya is offline
Old 12-11-2006, 09:58 PM   #2 (permalink)
Red face Re: Which motherboard should i opt for my core 2 duo 6600?
ASUS P5B.......who said this NOT a Good Board ?
vinyas is offline
Old 12-11-2006, 11:27 PM   #3 (permalink)
assasin's Avatar
Default Re: Which motherboard should i opt for my core 2 duo 6600?
Buy the Asus P5B DLX.
assasin is offline
Old 12-11-2006, 11:31 PM   #4 (permalink)
P5B Deluxe if you can afford it, else Gigabyte DS3.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 12-11-2006, 11:47 PM   #5 (permalink)
Thumbs up Re: Which motherboard should i opt for my core 2 duo 6600?
If budget is not the constrained then go for MSI 975X Platinum PUE (judged best MoBo by Tom's Hardware) http://www.tomshardware.com/2006/10/...or_core_2_duo/
You can buy it online from www.yantraonline.in
monkey is online now
Old 12-11-2006, 11:50 PM   #6 (permalink)
soumya's Avatar
i want to go with 965 chipset!! and also suggest me a good cabinet!
soumya is offline
Old 13-11-2006, 08:02 AM   #7 (permalink)
P5B DLx ... is a Good 965 Chipset Board ... Go For Cheiftec Or Antec Lan Biy
vinyas is offline
Old 13-11-2006, 04:16 PM   #8 (permalink)
anu0512's Avatar
Cool Re: Which motherboard should i opt for my core 2 duo 6600?
ASUS P5W DH DELUXE IS NICE BOAD IT EXPENSIVE AND GOOD FOR OVERCLOCKING. IF ANY ONE BUYING A E6600 SO PLZ GET THIS BOAD BECAUSE THE C2D E6600 IS ALSO EXPENSIVE THAN MOB .
OVERLOADED MEMBER
anu0512 is offline
