I own a Mercury 845GLM-P Mobo, Cel 2.00Ghz Proc and a 64MB GeForce MX440 AGP Card.
I've plugged the card onto the board but when I try to connect the Monitor cable to the card, there is no display. Neither there are any error beep sounds.
The card is working fine on my other system- Intel 815(FIC) & Pentium III-733 Mhz Mobo & Proc.
Plz. suggest the cause and cure of the problem. Is there a need to change the jumper settings on the board which disables the onboard video agp.
If yes kindly suggest how to do that.
